B with hand brakes? |
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Topic: B with hand brakes?Posted: 11 Sep 2012 at 10:31pm |
I'm looking at a B that my wifes uncle has, wf, hyd, woods mower, but it has hand brakes and i've never seen this before on a B. is this common?, factory?, aftermarket? i'll try to get pics and a serial number. i also has some type of bracket behind the seat and in front of the platform(foot rest). the front one has been adapted to take a cyl. for lifting the deck. i'm assuming that these are for hanging some type of mounted equip, cultivator maybe?
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
DanD
Posted: 11 Sep 2012 at 10:54pm |
Early B and C tractors had hand brakes.
MilesGray (CO/KS)
Posted: 12 Sep 2012 at 12:17am |
All my 38's and my 40B have or originally had hand brakes. My Grandfather's B has a mechanical lift for the mower and my 44C has hydraulics. The Bracket behind(?) the seat may be a rock shaft that was/is used to help keep the implement pushed toward the ground. the B's also had implements that could attach under the tractor (where the mower deck is). Pictures are always appreciated :-)
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
jeffsh
Posted: 12 Sep 2012 at 7:01am |
MY 38 B HAS HAND BRAKES,LOVE TO SEE YOUR B!
B26240
Posted: 12 Sep 2012 at 7:12am |
My 39 has hand brakes
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 12 Sep 2012 at 9:16am |
Allis started putting foot brakes on the B's in 1941 I belive along with the C's, The C's only had foot brakes for 1 year, 1940 was the first year that lights and starter were availible on the deluxe B, as they called it.
RichinWis
Posted: 12 Sep 2012 at 9:18am |
the C only had hand brakes for 1 year, sorry.
David Gibson (OH)
Joined: 30 Oct 2010 Location: Hollansburg, OH Points: 493 |
Posted: 12 Sep 2012 at 9:46am |
My 1941 B had hand brakes.
Jamest1982
Posted: 05 Jun 2024 at 3:40pm |
Does anyone know what the threads are on the hand break levers. I am trying to clean the up and want to run a die over them but can't find the correct size. The small locking levers are 1/2 13.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89177 |
Posted: 05 Jun 2024 at 10:32pm |
lever ends are 5/8 inch - 18 thds per inch... National Fine Thread.
if you have a dial caliper it should read .625 inch OD Edited by steve(ill) - 05 Jun 2024 at 10:36pm |
Brian G. NY
Posted: 06 Jun 2024 at 11:04am |
I would guess the brackets behind the seat are the lift arms for plows and the "bracket" under the foot rests is the drawbar for attachiing the plows.
It would have been nice if a set of two-way plows had come with the tractor.
1939Dodge
Posted: 07 Jun 2024 at 6:53am |
my ‘39 B has hand brakes
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1084 |
Posted: 07 Jun 2024 at 7:21am |
You do realize that the 1st half of this thread is 12 years old!
