Splitting Stands
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: Splitting Stands
    Posted: 10 Sep 2012 at 6:45pm
I'm needing some pictures? ideas? for splitting stands for AC's. I am going to split my CA for the engine clutch and again for the main trans seal. I would like to build one that would also work for my 175 diesel if needed in the future.
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 6:55pm
This is what I made for my WC worked great for moving the front around to get it out of my way. 2 pieces of channel iron, a turn-buckle with a couple bolts and a K car rear spindle. And the turn-buckle makes the height adjustableSmile
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:08pm
That is pretty slick Charlie.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 8:25pm
If I had to split a 190 or sompin heavy, I would maybe beef up the pivot point a little and center, or double up the turn-buckle. I'm not sure what K car spindles would handle for weight so they could be replaced with somethin heavier too.
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 9:36pm
so that's lena in her underwear?
looks very handy - easy rolling anywhere even on dirt.
52 CA, 41 B and a little B1    oh, yeah... and an 8N ford snuck in there, too.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 2:04am
I need to build some too... I'll make TWO sets- one that holds the back of the frontend, another that holds the front of the rearend. I'll probably rip the rearend from a Geo Metro, since there's a carcass in the driveway that needs to be dismembered and re-purposed. I like the adjustability concept.
Charlie- is there an advantage to NOT having the two sides coupled together... like... it allows something to be dropped down below the frame or something?
Mine will need to be adaptable to the WCs, WD, D17, and B's... no clue how I'll do it, but I'm certain that several things will happen:
1) I'll spend quite a bit of time contemplating it... probably right up until the time that I actually need it... and then, I'll get it made just a bit later than sensible...
2) I'll spend just a little time building it...
3) I'll spend about twice the time kicking myself for overlooking some really obvious things...
4) I'll change it later...
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 5:56am
Dave, I think you're good to go!
Edited by JoeO(CMO) - 11 Sep 2012 at 6:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 6:44am
The advantages are: less material needed, lighter weight for handling and easier storage.
Once I had the frame rails cleaned and primed, I could bolt them back up to the pedestal and bell housing. That's when I made the stands.  I needed to be able to work on more than one thing at a time, in case I ran into a snag, and the wheel stands made that possible with limited work area.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 7:20am
Charlie I think thats the best setup i"ve ever seen !! and with two pieces it will work on any width outfit. Also I really like the easy roll concept -- to  get room to work on either end.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 1:11pm
I made wheelie bars  for my WC that I can  can swap sides to  extend forward  as splitting stands when needed.  I'll post a photo soon of that , I plan to be  splitting to install the clutch  in a week or so.  I may use scaffold casters instead of the wheelie pads if I need  more mobility.
DaveCinIN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 10:05pm
Here are the splitting stands that I plan to copy. Maybe just a little heavier.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 10:11pm
Here is another set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 3:38am
Thanks for the pix, guys!!! Anybody got s'more?
Question- When you split it at the back of the engine, or towards the transmission, obviously the rearend, sitting on tires, becomes a concern of proper support, and unfortunately, stability.
Gary's setup illustrated support for situations where the front of the transaxle wants to flip skyward. WHICH tractors need aft support to keep from flipping up, and which ones will flop DOWN?
Obviously, this is subject to some variation based on WHAT is being serviced, so perhaps the best way to answer it, is to refer to the specific model, and indicate under which conditions (split location, and service operation) will the rearend be subject to flipping back, or dropping forward...
Or would it be easier to just devise a rearend frame that simply sits under the rearend at a high-enough elevation, so that it's being suspended at the same plane as the axle tubes, so the transaxle's center of gravity is essentially BELOW the support point (hence, it WANTS to stay level)??
And as a caveat... the EASY answer is to say "use the overhead hoist"... which, if I was doing a short-term task that didn't involve shufflin' stuff around, would be perfectly fine... however, if I've got two WCs, a WD, and a B in the workshop, I can have all of them split, and on stands... and still have the overhead hoist free to do something other than be a perpetual hanger of tractor parts...
Edited by DaveKamp - 12 Sep 2012 at 3:40am
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 12:09pm
I remember my dads dealership had very similar stands both purchased and shop built. He had two and four wheel versions with two and four risers.
1944 Allis C
1960 Allis D-17 LP
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 12:22pm
When I had my C split fore and aft, the engine was supported by a hoist, the torque tube supported by two stands that we made and the rear drive/PTO rolled back and rested on the drawbar. Once I removed the part that needed replacement (PTO Shaft), I used a Jack to bring the final drive back to level.
And thanks again, Steve!
Edited by MilesGray (CO/KS) - 12 Sep 2012 at 12:24pm
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 6:35pm
Thanks Much To ALL!!!
