Bad day for 175
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Bad day for 175
    Posted: 10 Sep 2012 at 3:05pm
One of my friends helper was raking hay when this happened. Has oil on the ground also so not sure what all got damaged.
Edited by Charlie175 - 10 Sep 2012 at 3:05pm
Charlie
rms61moparman(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rms61moparman(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 3:12pm
Don't know but one way to say it!!!!!
THAT SUX!
Mike
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 3:50pm
If that happened to me...I would need a change in underwear.
"Better By Design"
Sid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sid Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 3:57pm
OUCH!
       I just about had that happen. Was giving my 170 a look over before going to mow and the pin was just about to fall out.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 4:43pm
Oh boy.  Glad no one was hurt.  Bump on the ground or on top of the front end may have punched a hole in the pan.
I need to go check my 170 next time I'm at the farm.  Just mowed with it Saturday and have never thought to check other than to grease it.  Thanks for reminding us all.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 4:49pm
I guess you fellows have never had a WD or a WD45 do that? It is quite common when the pin breaks or the hole gets too worn out.
Just saying....have a look and be safe!
regards,
Ken McGregor
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 4:59pm
Ouch!  I was bushhogging with my 170 gas with the front pump one time and had the big pin slide out half way.  Fortunately I noticed the front end moving around before it came all the way out....I was doing some steep hills at the time, so it could have been bad.
ALLIS EXPRESS!
This year:
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 5:44pm
Not trying add insult to injury but that looks like a pretty straight tractor other wise, hope it gets fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 5:45pm
Every other year, I bust a spindle out of the D-12, cutting hay with the big bastard drum mower!  I have to keep the front end weighted down, and when I hit a groundhog hole, while turning, that generally does it!  Last year, I turned right, and saw the left wheel sag out at the top of the spindle.  Gave Brenda a call, said send me the usual!  Got the repair down to about 20 minutes.  If I am in a hurry, I steal a spindle off'n the D-10.  I'm thinkin of mounting the drum mower to a D-14 NF, that I have doing nothing, right now!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 6:36pm
My 175 ALMOST did that to me once but I caught it just in time. I turned me a new pin with a cap on one end and drove it in from the front because the oil pan is in the way. Drove it in 3 or 4 inches and cut the old one off with a torch. I milled a hole in the end of the pin and put a half inch grade 8 bolt with double jam nuts so that won't happen again. I'm glad no one was hurt but the oil is probably the result of a busted oilpan.
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 6:40pm
Glad no one was hurt. I know someone who was killed raking hay on the same tractor that the same exact thing happened. It must be something that happens occassionally with these. Good time for everyone to go out and check their tractors.
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:00pm
I have never seen that before we have had two 170's currently have 175 just lucky. I have seen that of a K2 the back axle broke on ours and one at work design flaw. Glad no one was hurt
Morley
Farm stuff 8050,6690,175,F2,5050,WD
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:07pm
Can you lift yourself up with the loader and get a quick look without hurting the motor?
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 8:25pm
that happened to my mom once on the ol d17 needless to say she wasnt happy , wasnt that bad but close, nothing was hurt including her
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 10:06pm
Morley
On mine the small bolt that holds the big pin in came out, don't know if it broke or lost the nut and shook out....I think lots of bouncing around will do it, such as raking or mowing in a dry rough field.  Now I check mine every time I grease the front spindles.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 10:12pm
Looks like the grill guard saved the grill. If so that is a plus. Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 11:19pm
Or pull another tractor close and hook up hydraulic lines to push loader down to lift tractor.
On another look those may not be two way cylinders?
Edited by Pat the Plumber CIL - 10 Sep 2012 at 11:21pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 6:13am
I've seen the rear of the axle yoke broken a few times on 190,180,185 etc but not the entire front axle come off. An uncle had a really worn out D17 nearly do that while he was mowing ditches for the township. He wired it with #9 wire enough to limp it home. I have seen a couple IH and Deere tractors lose their entire front axle a couple times. Neighbors 1206 comes to mind and another neighbor with a 5020 Deere. Saw a 656 narrow front snapped off and the old farmer said he had to replace that narrow front every once in a while just for that reason. A friend's 1755 OddLiver had the front pin so worn that it shifted back and forth while driving but the rock box held it from completely coming out. He didn't seem too concerned even though he lives in the hills of Caledonia MN.
Edited by Lonn - 11 Sep 2012 at 6:14am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 6:32am
They used a backhoe to lift it up and drag it to a trailer. Back in the shop now. I will check with him to see what the damage was.
Charlie
AllisUpstate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 8:40am
I looked over my D17 IV front.  The pivot on the rear bracket is a large 1" or so bolt with castellated nut.  The front pivots on a rod into the steering assembly casting.  Where does the problem typically come from on these front ends?  Does the rear bolt let loose, or is it in the front pin?
After looking at the 175 pictures, now I'm nervous and trying to figure out where mine could possibly give way.  It looks to me like the rear pivot bolt is the one to watch out for - is that correct?  Also, I'm not sure how the D17 IV setup is different from a 175.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 8:48am
The front end is entirely different on the 170/175 with the front mounted hydraulic pump....which this one appears to be. It has a single large pin that holds the front end on,
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 8:49am
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 10:48am
Results:
Retaining bolt came out at some point and the long shaft slide back allowing the front end to drop which then snap the shaft at the back. Front end then rolled under the tractor breaking the hydraulic lines to the loader (which was the oil on the ground). Luckily the loader bucket was low at time and helped hold the tractor up from nosing into the ground more.
Needs New Shaft, steering ram, and hydraulic fittings
Charlie
allis 7045 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis 7045 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 4:46pm
when im doing anything with out loader tractor such as raking hay i run the loader close to the ground just in case this ever does happen
ac 170, 2 ac 6080's, ac 7045,gleaner k, gleaner l2. all going strong
Longmeadow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 5:58pm
I hate to rain on anyones parade, but why are you using a tractor with a loader on it to rake hay?  The newer style front axle assemblies, with a roll pin are not actually engineered to withstand the rigors of supporting a loader( no grease fittings) and neither are the front axles/spindles... in a field environment. In case anyone wants to argue the point, I bought a new 175 in 1980 and have had actual experience in a intensive agricultural environment. I have had the bushings replaced along with the roll-pin, et al.. a number of times and replaced spindles, etc. ..finally resorting to adding gussets to reinforce the front axle assemblies, I keep my 175 close to the barn... nice loader tractor, but I take the loader (Bush Hog 2426QT now) off for any extended field work....forcing grease in using a needle tip and replacing worn bushings when the front end gets too slpppy. Raking hay in 3rd high range , with a loader on, is just about the worst front end abuse I can iimagine.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 7:28pm
Not long after dad got our 57 D/14 he noticed the front pin didn,t go in much as it could. He got a 3/4 plate and put on rear plate pushing the front axle asembly  forward 3/4 an inch. Never had a problem so far.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 11:10pm
That's a wonderful demonstration of armchair sportsmanship.
You may be correct in your analysis of the machine's durability record, but would it be appropriate, under the same auspice, to declare it unfit for operation with a 2500lb stack of suitcase weights hanging off the front? Would it be appropriate, under the same auspice, to declare it unsuitable for being fitted with a 500-gallon sprayer tank up front, and a 40' boom in back? How about a mounted corn picker, or a 7' tall V-blade?
Fact is, it's a FARM TRACTOR, and someone who's engaging in agricultural practice will employ the tools they have, to do what they do.
A condition of failure occurred, and while it may have been clearly obvious to you, there's a much higher likelyhood that the operator never had, nor heard of the prior experience. Furthermore, it sounds by your, and others' descriptions, that the failure isn't relegated to use of any particular implement in any particular environment, but rather a condition that the machine's design and manufacture exhibits, and apparently goes unnoticed.
As for use in haymaking, if I had a loader, I'd have extension forks and'or a grapple, or mebbie even a bale-spike in it, and use it to load round bales onto a hay rack. If you had a tractor with a loader, wouldn't you?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2012 at 7:56am
Excellent observations & criticisms Dave and I humbly apologize if I offended anyone's sensibilities.  I do use my 175 in the field to pick up and load round bales, but I don't travel at raking speeds. And if I'm in a rather bumpy/rutted field I slow down and/or use my 4wd drive with radial front tires that cushion the blows of a rutted field with a big bale on the loader. However, being a trained engineer I have a significant interest and affinity for using the right tool for the job and of being respectful of the limitations and advantages of each tool. I suspect I take the same approach with my tractors, sometimes without really thinking about the inconvenience to me or my farming operation. I also have had the lesson of experience..seems that I got lazy a few years back and hooked my 175 to a small disk..big disk was down and need of repair... and went out and disked a just plowed field for an afternoon,loader and all. When I got back to the barns/shed that evening I looked at the front end and I had damaged the front pin bushing..needing repair. My thoughts at the time went something like "why were you so stupid"..  I suspect I'm lucky enough to have options regarding what/which tractor to use and I probably forgot that. I guess I shouldn't be so caustic... or is it judgmental.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2012 at 1:31pm
There's several facets to issues like this. Many of us have engineering backgrounds, some of us formally, but many through the life experience and self-education. The engineers that designed our machines were educated both scholastically, and through experience, and when looking at the long-term performance of a product, and the product's redevelopment over long term production, frequently illustrates the focus and skill level of the engineering and design staff. Furthermore, it illustrates how attentive they are toward reviewing not only the products' performance in it's intended environment and use, but also whether the product is being utilized in an application or manner OUTSIDE of it's design intention.
In most ANY environment, a product which is truely successful over long-term production, is one which is closely observed by the staff, and 'jealously' watched-over... partially for reliability and durability, but also for reason of expanding the product's functionality and flexibility. A durable and reliable product is paramount to long-term success, because the customer base will not invest in something that will not provide expected lifespan, but being functional and flexible assures that the customer base will find more ways in which their investment can be employed. If I were to ever be employed as a working design engineer, I would only be satisfied to be IN the field, checking machines, seeing how they are being employed, finding problems, and correcting the design and manufacturing to further the product... I simply could NOT be satisfied to sit behind a computer and design something to production, and then move on to another product. Alas, the latter seems to happen even more today.
In the case of the 175's axle pivot, it's clear that failures occured, and that circumstances of use affected the rate and nature of failure. On a smaller scale, enthusiasts have found that IH Cub Cadet garden tractors suffer a similar failure... and for very similar reasons. Paying close attention to the pivot, and addressing issues early prevents catastrophic failures from occuring, while simple modifications can provide an essentially 'permanent' resolution for MOST uses.
From the perspective of a consumer, the presence of an option or feature, particularly one designed BY the manufacturer and/or sold THROUGH the dealer network specifically FOR the machine, should NOT require any change in daily use or operational philosophy by the consumer, with exception of those basic concepts of the added item's presence... an example being center-of-gravity of a lifted load... one would not operate a loader with an elevated load, and expect the machine to perform with the same stability as with no loader, and no elevated load. The consumer would not, however, be immediately aware that the presence of the loader, even without it's load, to result in accelerated wear-and-tear on the main unit, simply because they're driving across a bumpy field.
Wether or not the loader was actually original to the 175's design, I think, and I suspect you concur, that the real failure here is in the 175's pin and pivot design philosophy... if it fails from being slapped around under the presence of an FEL, or any OTHER implement or attachment, then it's not stout enough in an overall sense.
The unfortunate situation, is that most of these agricultural machines are so durable, and so easy to use. My grandfather could send his teenage daughters out to the fields with WCs, WDs, and WD45s to cultivate using machines that six decades later, both the machines, and my mom, are still alive and running well... and for all practical purposes, while relatively 'retired', they're both a LONG way from being 'worn out'. Nowdays, a kid (and when standing alongside a machine that my grandfather would have bought new, I consider myself to be a 'kid') would hop on a machine equal to their age, or even older, and expect it to be totally safe and dependable under anything but idiotic operation... only to have an incident like that shown above. I'm sure the poor fellow got quite a surprise out of this. As an aside note, the original post identified that a 'helper' was involved. I'm kinda thinking the 'helper' may have been the operator. If I was an energetic and enthusiastic helper, and I was asked to operate a machine, I'd probably trust the machine a bit more than I should... (because I've been in that situation once or twice).
I always try to find something positive in light of an unfortunate situation. In this case, lessons were learned the hard way. The blessings:
1) Nobody hurt
2) Damage minimal, and quickly repairable.
It could have been much worse. Going downhill, with a triple-tow of loaded hayracks behind... crossing a ditch... and a funeral.
Finally, it has been illustrated here... and we can thank the presence of internet forums- we can take it upon ourselves to remember this lesson, and share it with everyone who MAY NOT already be aware that conditions like this, can result in this, and even worse incidents. When we see these old girls being worked, to take a look for ourselves, and if we see something awry, to act upon it immediately- to let the operator know that there's a problem, and head-off accidents BEFORE they happen... and not just for 175s... but for EVERYTHING.
In reality, there is no device or law, no seatbelt, air-bag, or warning message that will keep anyone, or anything safe... with exception of just ONE thing:
Your brain. Use it, or lose it.       Always better to share it with others on your OWN terms, rather than having them mop it up off the ground after you've been squoooshed.
Edited by DaveKamp - 16 Sep 2012 at 1:34pm
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2012 at 6:17pm
Unless it was the only tractor I had, I would'nt rake hay with the loader on either.
This page was generated in 0.126 seconds.
