Cotton pickin season is comin
James Coons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Topic: Cotton pickin season is comin
    Posted: 08 Sep 2012 at 1:23am
Got the 116 picker home and got it mounted on the D17.  Thanks Henry!
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 3:53am
Wow! What a project! I have not ever seen anything like that. Looks like a  job well done. Lets see some pictures of some of your other treasures..  Dave.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 4:47am
That's great James. I'm glad you finally found one. I know you have been hunting for 2 or 3 years at least. God Bless.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 7:51am
How do the controls work? Electrical ,clutch,steering,shifting???
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 7:54am
#Wow - that's an interesting machine. Guessing it took a while to get set up.  Looking forward to hearing how it does.
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:10am
That looks like it might be a little top heavy. Very interesting machine! Never seen anything like it! Post a video of it in action for us.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:25am
Looks a bit tricky to mount! Nice machine!
Greg Kroeker
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:33am
That's a great find!! I think there are not very many of that model.Most of the pickers you see are the 616's where the tractor is reversed under the picker.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 9:17am
WOW! There aren't many of those left! That one is in very nice condition, must have been inside it's whole life. Be sure to post up videos.
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 10:10am
Nice looking machine. Don't see many of thoose in Western MD. Are you going to use it? Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 5:12pm
Wow , How cool is that. Would love to see some pics of how the controls connect.Also would love to see a video of it in action. Watch for low lying branches and dont pop the clutch.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 6:29pm
I've parted out a 616 to get the tractor out from under it before. I also know where there is another 616 if it hasn't been sent to china yet. Fascinating how they were integrated onto the tractor base.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:28pm
My first thought was -- theres a tractor under there? ? Oh there it is !!
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:39pm
boy, that must be fun to mount.  and I agree with the top heavy comment.  very interesting to see.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 9:06pm
Thanks so much for the pictures!Looks like the d-17 is hiding! Take more pics if you can, when its in the field takin cotton off, as you can guess us northern boys have not seen a cotton picker in action up here! Lol
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 10:02pm
Thanks Dave!  I'll have to see what other pictures I can dig up next time i'm down on the farm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 10:16pm
The clutch and brakes are worked with hydraulic master/slave setups similar to what you see in automotive applications.  The slave cylinder for the clutch mounts on the floor plate and the brake slaves mount to a bracket that bolts to the transmission just beneath the floor plate.
The electrical has a pigtail that slips under the hood on the right side and has eyelets that bolt into the tractor's main harness around the battery & starter relay area.  It even has the same color and gauges as the tractor which made it easy to see where each one went.
The steering has a chain drive that is turned by the wheel on the picker that in turn drives a universal shaft that bolts onto the tractor's steering wheel using a triangle shaped plate.
The transmission is shifted with a rod linkage assembly.  Its interesting to shift, the shift pattern is upside down and backwards!
All the other controls pto, range, throttle ect are all done through rod linkage as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 10:20pm
We hope to do a little playing in the field with it one of these days.  There's still somemore work to get her ready for the field.  The head unit is currently stuck most likely due to sitting on the ground and rusting up the bottom drive chain.  It will sure be neat to see it working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Coons Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 10:25pm
I will get some better pics of the controls next time im on the farm.  It is pretty interesting how they mate up.
Thanks everyone!
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 5:10pm
WOW!  Thanks for posting the great pictures!  Hopefully you get get it freed up and running.  The paint and decals look great.  A truely great find.
Jim
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 7:50pm
Way cool!!! what is the tank for behind the pickers operator platform? And i used to think it was a pain to mount the two row picker on dads D 17
