WD hand clutch
Message Reverse Sort Order
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: WD hand clutch
    Posted: 05 Sep 2012 at 7:10am
you see them 3250 to 3500
Cody nwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cody nwo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 10:26pm
I'm not sure that I really need to lose the weight, how light is everybody else runnin their wd's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 9:06pm
You can loose 50 easy pounds by removing it just need another hub to slip on rear end shaft then bolt together a one inch plug will go in wbere shaft goes through case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cody nwo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 8:05pm
Does anybody have any pictures of a bolted hand clutch in a wd? I'm going to try to run mine without doing anything with it for a while but eventually I plan to make it so it can't slip there
