Rear rims
LRWSPWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LRWSPWI Quote  Post ReplyReply Direct Link To This Post Topic: Rear rims
    Posted: 30 Aug 2012 at 8:45pm
I was wondering if Allis ever made a wider rear rim as an option for the 7000 or 8000 series that would still fit a 190 or 200 tractor using the 18.4- 38 tire. I would like to put a wider tire on my 200 using a wider non spin out rim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 9:55pm
20.8 x 38 (18 inch wide rim) non spin-out wheel from any 7000 or 8000 series should work on a 200 that already has non spin-out 18.4 x 38 inch wheels (16 inch wide rim).
Post Options Post Options   Thanks (0) Thanks(0)   Quote LRWSPWI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 5:46am
Thanks DrAllis I'll see if I can score a pair.
steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 12:08pm
if you go with the big metric tires could you post a pic
51 CA, 57 CA, 53 CA(in progress)
