allis h3 dozer color |
blrott
Topic: allis h3 dozer colorPosted: 29 Aug 2012 at 5:00pm |
need to paint allis h3 dozer with 6 way blade. anyone know what the correct color is for this machine. believe its a 1961. thanks.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 29 Aug 2012 at 5:57pm |
If it was sold as farm then orange ,
if sold as industrial then yellow. they made them in both colors depending on the dealer they were sold through
ratchet
Posted: 30 Aug 2012 at 7:52am |
I usually sand an area on the machine to get down to the original color to see what it was born with or look at an area under the seat where it probably was not sanded very well in past paint jobs you may find the color there. Good Luck!
1956 HD6G , 1958 HD6G , 1963 HD6G,massey harris 20,case 995,huber,jd 350 , 1956 onan generator,poppin jonny ,massey ferguson, internatinal backhoe, i work on anything and everything its an addiction!!
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 30 Aug 2012 at 8:04pm |
Ages Cat
Posted: 30 Aug 2012 at 8:21pm |
The HD3 is DAR 81985 Delstar. PPG no longer mixes that particular color , however. there replacement for it is Concept DCC 81657. This is Allis Chalmers construction yellow which was listed in the PPG manual years ago. There were several different shades, the earlier being less bright. The wheel tractors are Concept (painted later), the crawler Delstar (DAR). Look under the fuel tank and match that color, if you have an earlier HD3.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10937 |
Posted: 30 Aug 2012 at 8:59pm |
I took a part from my HD4 from under the seat to NAPA. I think it was Loraine Yellow , it matched the dozer pzrt perfectly. Napa was able to match it in thier Martin Seynour paint. Really looks good on the parts I painted. HTH Tracy Martin
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5206 |
Posted: 07 Sep 2012 at 12:14pm |
THAT INDUSTRIAL YELLOW LOOKS TO ME LIKE TERRAGATOR YELLOW.
orangeman
Posted: 07 Sep 2012 at 3:34pm |
I did a bit of research on this years ago, was told by AC Industrial Staff that AC had up to 12 different colors of Yellow listed for its equipment. Confirmed this through NAPA at the time. Settled on Lorain Yellow for my 615 and H-3. Good luck there are a number of good ways to achieve color match as noted above.
