hd6g 1963 model wet clutch
ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Topic: hd6g 1963 model wet clutch
    Posted: 26 Aug 2012 at 6:16am
What oil does the wet clutch take ? regular hydralic fluid??? Thanks
1956 HD6G , 1958 HD6G , 1963 HD6G,massey harris 20,case 995,huber,jd 350 , 1956 onan generator,poppin jonny ,massey ferguson, internatinal backhoe, i work on anything and everything its an addiction!!
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 3:44pm
automatic trans fluid 10W. Any of the dexron grades will do. 9 quarts in them I think
Edited by Mactractor - 26 Aug 2012 at 3:51pm
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 6:18am
Are wet clutches only on HD6GB machines? Do wet steering clutches have stronger springs that require hydraulic power for the throwout bearing? If not can an earlier HD6 be converted to wet steering clutches and master clutch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 9:33pm
Wet master clutch conversion should be no problem, but the wet steer clutch tractors had some slight differences in the rear housings. Years back, I tried to fit the fine spline bevel gear shaft and pinion shafts to my dry steer HD6 (with the coarse spline shafts). Wouldnt work because the shaft bearings had different outside diameter. The wet steer tractors had bigger bearing bores.
To make an HD6G wet steer, I thought of fitting the 6G frames and loader assembly onto an HD6EP. You would then have hydraulic steer and power shift trans. Be a very formidable little loader. Be no yellow equipment come anywhere near you.
This page was generated in 0.045 seconds.
