D17 Series IV Brakes
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Brakes
    Posted: 25 Aug 2012 at 4:43pm
Hey guys, I haven't ever been into the brakes on a series IV.  Plenty of D19, 190s etc. but those are all outboard brakes, (i.e not directly on the final drive shaft).  I have also done many Series I, or II, but that's also a different story.  By going thorough the parts manual, it appears that I can pull the final drive off, WITHOUT taking the brake band apart, is this correct?  Secondly is the friction surface for the outboard side of the disk portion machined into the final drive housing?
Thanks,
Anthony
Still in use:
paul s. mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 5:05pm
i have the same thing, would like to see the answer to your question.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 6:42pm
[QUOTE I can pull the final drive off, WITHOUT taking the brake band apart, is this correct?
Yes, that is correct.  The band can be installed and taken apart after the final drive and axle are removed.
 The friction surface is a plate held in with three bolts.  Has shims behind it to maintain the correct clearance between it and the friction surface on the differential carrier.
Thanks,
Anthony
[/QUOTE]
Here's a link to the parts diagram.  Go there, then click on brake.  On the picture that pops up, the friction surface to the outside is #8 in the diagram, and the shims are #9.
http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001558
Edited by DanD - 25 Aug 2012 at 6:48pm
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 10:02pm
Pretty easy to understand after you do four of them......
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 10:08pm
Thanks DanD, that's what I was looking at to come up with my questions.  :-)
The friction surface I am talking about is not what I think you are suggesting.  With this setup there are what I think are two contact points.
1. the round beveled surface that you are speaking of, that bolts to the inside of the rear housing, the drum friction surface contacts this, outboard of the balls, is a friction disc, that must contact something.  This something would have to be inside the final drive housing???  Am I right?
Eldon, I bet you took some pictures when you had your apart, I know it. :-)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 10:11pm
Or did Allis kinda draw it out of order, does that beveled iron, bolt over the entire brake assemble, and the Disc, contact the inner surface of that piece?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 10:23pm
The shims go on the final drive side. If you have the IT manual it is pretty clear once you get everything apart. I parted out a 170 and 185 so had plenty of shims when I started, so that helped me out. I think they are also the shims used in the Wd/Wd45 hand clutch. Sorry, I get busy and the camera doesn't come to mind....but the last one I did, I did the RH side in an hour and a half, and that included riveting on new brake facings (bands came assembled).
ALLIS EXPRESS!
This year:
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 12:17am
When you remove the rear axle housing from the tractor, you'll be able to reach in and pull the plate & drum unit off the axle shaft.  Looking at the parts list, parts 3 and 5, the plate and drum will be together in one unit, held together by the two springs, #2 in the diagram.  Trapped inside will be the four steel balls that ride in the sloped ramps that are cast into the drum and disc.  When you step on the brakes, you'll see that the band, part #7, clamps down on the drum.  Notice that the drum is not splined to the axle. However, it is attached to the disc by those two really tough little springs and the steel balls are inside ready to go into action.  The disc portion is splined to the axle, but free to slide back and forth.  Now, the band is trying to slow the drum portion, but not the disc.  This results in the disc and drum turning slightly with respect to each other.  Now, because of the steel balls inside riding on the sloped ramps, the drum and disc are forced apart from each other.  The brake lining on the back side of the drum (not visible in the picture) is forced against the friction surface part #8 in the diagram.  This is outboard of the brake unit.  It will still be in the axle housing when you remove the disc and drum unit.  The lining on the disc portion is forced against the friction surface on the outboard side of the differential bearing carrier.   This surface will still be on the tractor when you remove the axle unit.  Remember that this movement is not much.  There's only a few thousands clearance between the brake linings and the friction surfaces when the brakes aren't applied.  You don't want it too big or the springs (#2) stretch too much and break.  They usually are broken when the brakes are bad anyway.  And you'll want to put new ones on anyhow.  This is why it's important to have the correct shims behind #8 so that the clearances are within limits.  I don't recall the exact measurements, but will be in your shop manual.
CLear as mud?  When you have it apart, it's pretty easy.   I've done brakes on a Series III D17 and a 185 and both are still working well today yet.
Edited by DanD - 26 Aug 2012 at 12:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 9:00am
I think I'm with you now, this view is from the perspective of the right side of the the tractor looking across the tractor at the left brake assemble side, not looking at the near side.  Sometimes these veiws sure could use a "front of tractor" arrow, like many of the other parts books out there.
Still in use:
