HD6G TOOLS
ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Topic: HD6G TOOLS
    Posted: 23 Aug 2012 at 1:09pm
TWO OF THE FIVE TOOLS I HAVE MADE SO FAR FOR THIS MACHINEII WILL POST THE OTHERS LATER.
1956 HD6G , 1958 HD6G , 1963 HD6G,massey harris 20,case 995,huber,jd 350 , 1956 onan generator,poppin jonny ,massey ferguson, internatinal backhoe, i work on anything and everything its an addiction!!
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 3:46pm
Tools that do the job. That track pin looks to be in excellent shape. What do you use to pull track pins wityh the track on the machine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 5:19pm
A ( B F H  ) and a punch . Punch has a handle on it so as to hold steady by helper while you use hammer . You can make up a sleeve to center punch onto the track pin , this  bolts to the track link so punch does not need to be located after each hit.
 On the pin (opposite side your driving from , buck the track link with a pipe or heavy metal bar to opposite track so hit is solid and not bouncing when force is applied.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 8:04am
Dozer, The hard way like coke said a BFH! actually with a oxy acethylene torch to heat it also. Coke thanks for the idea i will be placing a piece of pipe on my track assembly tool to incorporate taking it off also. Here are two other tools i built for it. one is for the 4 inch nut on the center of the drive sproket and the other is used with a bottle jack to pull the outboard bearing.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 8:18pm
by the looks of the weld on the track frame on the last pic that sprocket was changed without removing the trackframe. coke has talked about this before. nice tools, i like the pin lineup tool. we meed some pics of the whole nicely painted loader though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 11:37am
Yea that is where I got the idea after several hours of messing with the pin on the track frame I went that way it seems to work pretty good , I've put the outboard bearing on after I welded it all back up and it was aligned pretty good no problems I will post a pic of the bracket I bolted up for alignment later.
This page was generated in 0.275 seconds.
