wd bearings
Nautyboss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautyboss Quote  Post ReplyReply Direct Link To This Post Topic: wd bearings
    Posted: 22 Aug 2012 at 4:53pm
I have a 52' WD and I don't know which bearings it is supposed to have, if they are standard, .010, .020, etc. How do I know.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 5:04pm
If the crank was never ground and doesn't need to be ground is needs standard. If it was ground or if you have it ground you need to order bearings to match the crank.
You need to measure the diameter with a micrometer and compare with the specs in the service manual
The universal answer to all questions is yes, how much do you want to spend?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 7:03pm
Dave summed it up about the brearing.
One think to add to Dave's post, The rods and mains in a WD are shimmed to spec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautyboss Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 7:24pm
Where is the best place to get a service manual that will have all the specs I need?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 7:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautyboss Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 9:41pm
Thanks, I've got the manual ordered. Can you tell me where I can get the main and rod bearings?
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 6:28am
We have some excellent vendors on this site.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 6:36am
Wertz power equipment .com
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 8:19am
Some machine shops will stamp the measurement on the crank after they machine it.
Edited by nella(Pa) - 23 Aug 2012 at 8:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 9:15am
WD's originally had shims for the rod and main caps. If the bearings wore over time and shims were removed, you would have no idea without capping them up and measuring the bore. If the bore is undersized (shims removed) you will ruin a good set of bearings by clamping them up. So it is important to not only measure the crank diameters but also the bore the bearing fits in. It is also possible that the rods have been re-sized without the shims and the block line bored without the shims.
All these measurements are CRITICAL for a lasting rebuild and need to be made in tenths of thousands of an inch.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 9:23am
I usually check bearing clearance with Plasticgage, that accounts for the journal and bore.
Since wear is not semetrical, you need to check clearence in two places on the crank, 90 degress apart. and, as already been pointed out, on WD, make sure you maintain the shims when measuring. If you need to have the crank turned, you can eliminate the shims in the process, if you want
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 9:27am
Lou, you can not eliminate the shims by grinding the crank. The bore the bearing fits in is round originally with the shim. If they have been removed, it's because the bearing wears top and bottom. If you want to eliminate the shims, you MUST bore the rod or main round, to size, without the shims in place.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 11:41am
Many bearing mfgrs etch the size on the back of the inserts; std, 0.10, 0.20, etc. Yours may be marked. Alwaays a good idea to mic the journals; rods and mains. If you want to rebuild using bearings without the shims you need to line bore the mains and rebore the connecting rods. Any good engine rebuild shop can do this at a reasonble cost. You can also remove the wick from the back of the crank, tap and plug it and install a bearing type pilot bushing in the flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautyboss Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 12:59pm
I'm not sure what you mean by the wick (I'm new to this), but hopefully the service manual will have the info I need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautyboss Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 1:02pm
Thanks everyone for you posts. When it comes to the shims, will the service manual have the info on where and how many goes where; I'm not sure they are all there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 1:13pm
WICK- The crankshaft is drilled for oil passages. The back of the crank has a wick in the hole to allow enough oil to weep into the bronze pilot bushing in the flywheel. You can replace that bushing with a sealed bearing and plug the oil hole off.
SHIMS- In my experience, if you put the original amount of shim back in a cap that has been run with less than original, you will not have a round hole for the bearing to set in. The best thing to do is have the block line bored. What I did was cap things up, measure the bore 3 ways and shim to within .002 of being round. Then I honed the bores to the proper size. Call me cheap, but I had the tools to do it instead of paying for the machine shop.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 7:06pm
Boss  sounds like this is your first time into one of these, may I sugest two things - one read the manual r.e. bearing install to get a understanding of what they are talking about shims etc then number two take the block and crank to a rebuilder and ask them to measure AND look at the crank for roughness also have them install new cam bushing. parts for a rebuild are expensive and so is labor to have them do some of the work but if you mess up the result could be bad.  I have done probably a dozen of these overhauls but still take the crank in to have it checked out since this is what they do every day .
jboettcher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:15am
Question.
When replacing bearings, and if the wire is still on the main bearing bolts, cant yhe smae size bearings be installed and the smae number of shimms reinstalled?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:57am
A "shim stack" is used at 8 locations on the four connecting rods and six locations on the main bearing caps. Each new "shim stack" is .010" thick. Each new "shim stack" consists of FOUR thin shims that are .0025" thick and are glued together for the total thickness of .010".  The design premise was to peel off one thin shim at a time to make up for bearing wear. The safety wire on the bolts is always replaced when working on the bearings, so that doesn't mean anything. Grind the crank. Get new matching bearings to the freshly ground crank size. Replace all shim stacks with new. You're good to go for the next 30 or more years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 5:12pm
Originally posted by jboettcher jboettcher wrote:
Question.
Thanks
 My WC had been rebuilt at least 3 times before I took it apart. It had wires on the caps and does now too after I finished it. The wire is a common safety measure to keep the nuts from vibrating loose and has nothing to do with the shape of the bearing or journal.
 You could do that, if you are not interested in a proper rebuild. The bearing isn't the only thing that wears. The journals wear and to properly fit a new bearing most likely need polished or ground.
Edited by CTuckerNWIL - 25 Sep 2017 at 5:18pm
This page was generated in 0.242 seconds.
