Freeman loader blade mount
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Topic: Freeman loader blade mount
    Posted: 22 Aug 2012 at 12:16pm
Going to be mounting a blade on the front of my freeman loader on my D14. Does anyone have any pictures or diagrams that they used to mount for it? This is just a standard blade from a truck. Thanks.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 4:44pm
Grandpa had already welded a 'top link' on our loader frame.  I built my blade, but this is how I mounted it.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 5:54pm
I made a blade from an old 55 gal water heater and ran a heavy angle iron along the bottom. I drilled 2 holes and mounted it like Greg's then added  2 pieces of angle iron on the top cross tube for a top link. I used a piece of box tubing for a top link and drilled a bunch of holes for adjustment. If I tip it too far forward it digs into the driveway, if I lean it back, the angle iron rides on the ground and helps keep it from digging in.
https://plus.google.com/photos/101907304795732239945/albums/5690623262383557361
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 7:43pm
These may help.
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 9:25pm
Thanks Danny. I'm saving that to my documents. That top pic is the bucket I have out back. I use the home made blade more than the snow bucket.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 9:48am
I used the A frame from the snow plow so I can angle the blade. I plow a long drive and need that feature. Also it is not a paved road so I like having the plow springs in case I hit something. Sorry I don't have pics of the mount but I could get them. Makes it alittle long in front but works well.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 9:53am
mdm1 where'd you get those good chains? Are they still available?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 10:48am
Ken I bought them from a guy in Nodine MN. He actually had a couple of sets. They always need some repairs but I had road chains before and they are worthless. My tractors are not to far from you. In the Willard area.  Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 9:24am
Wow! This is great! Thanks. I will post how I ended up mounting it in a few weeks when I get back home.
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 8:34pm
mdm1
If you ever get a chance, please post a few pictures of your mount.  I was given a snow plow and would like to make a mount for it.
Thank you.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 1:32pm
Dean if you could wait till after next weekend I would be glad to. My tractors are at my cabin and I will be there over the holiday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 8:06pm
Waiting is not a problem, I am just grateful for your help. Have fun at the cabin!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 6:10am
That sure is one long 'trip lever' - taller than the muffler !!
Gary
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 6:26am
Maybe it's a short muffler! When I got this tractor the lever was bent around like a pretzel and I think the mount was cracked. Not knowing much about trip loaders and tractors(still don't) that is what I put on. It works. If someone has a pick of the factory lever on a loader I may consider changing it or I may have to grow longer arms!
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 7:04am
Dean here are a couple of pics of my mount. The A frame came with the blade but I had to make it fit my loader. The loader just bolts or pins to the frame and I angle it manually. Sorry the pics aren't real clear. If you need any more help just let me know. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 2:30pm
Awesome! Thanks for the pictures mdm1, this is exactly what I needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 7:43am
Well I finally got the blade mounted, ended up mounting it directly to the blade. Here is a pic of it. I think it turned out pretty good. Although I have a feeling I will have to weigh down the back tires. This blade is heavy, about 350lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 8:32am
Looks good. Weight on the back won't be as necessary for a blade as it would for a bucket. I used my 5 foot snow bucket and in wet snow it got real light on the back even with fluid in the rears. It's never been a problem pushing snow with a blade. The problem I had was snow before the ground froze hard and the blade would dig in too much. You might have to tip the top forward to keep it from digging in or tip it back if you want it to dig in more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 9:14am
Right now it digs in really well. For the first pass I plan on just lifting the blade up just enough to take some of the weight off of it. Then once it is packed down I should be good. Overall I am really happy with the outcome. Plus I can't complain as I got the blade for free. The cutting edge is a little buckled but it still sits level so I should be good.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 10:04am
Does the plow have shoes? I needed the springs on my blade because the road I plow has some rocks that appear from time to time. Plus they came with my blade and I need to angle my blade both ways. I have weighted rears and the most aggressive chains I could find but again I am plowing a farm field road.
Should work good for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2012 at 10:35am
No shoes on the blade, but it does have two pieces of 3/8" L shaped steel welded to the cutting edge. So there is a little bit of elevation. It will be used to plow a gravel drive way so I hope it works well.
