6060 gear shifter sloppy revisited
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 6060 gear shifter sloppy revisited
    Posted: 22 Aug 2012 at 11:42am
Got a 6060 with the 1 thru 4 gear shifter thats sloppy , i took the boot off and theres 2 dowels on each side that keep popping out - my question is what holds these in? If they are in its perfect but when they pop out it gets slooppy
Edited by DougG - 22 Aug 2012 at 4:02pm
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 8:08pm
We had the same problem with ours at about 5000hrs.  If you ground a gear the least bit they would pop right out.  I put new ones in and then put a gear clamp around them and have had no problem with them since.  Probably about time to replace them again, kind of forgot about that happening till seeing this post.
