D17 Stock Farm 3mph
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Stock Farm 3mph
    Posted: 21 Aug 2012 at 8:03am
Nothing fancy, my plain old stock tractor.
5000lb stock farm 3mph class
[TUBE]http://youtu.be/NQdLNSPQ4uk[/TUBE]
Edited by Charlie175 - 21 Aug 2012 at 8:04am
Charlie
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 6:35am
plenty of power, she doesn't have enough bite
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 6:51am
Yep, trying to figure out what to do about that.
Charlie
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 6:01pm
 Charlie, there are several things you can try.... I didnt see the front end rise, maybe a little less air pressure, longer draw bar, but if you can do it jump up a gear , I always pulled 4500, 5500 in 2nd on the low side, 18.4X 26's @ 6psi. Have you ever fallen asleep at 3mph?, I thought 3.5 was slow........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2012 at 5:41am
ha! yes 3mph is slow!
I'm in the process of wearing down the tires a little, adjusting the stock hitch to 20" (17 now).
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 8:26pm
Pulled today, had the camera pointed to the rear to see the tires how the traction is going.
Dry track, 5000lb, pulled 238' in 2nd low but ran out of power. Front only danced a little bit. WD45 beat me with a full pull and he had power to spare.
2nd pull in 5500 I pulled 178' in High 1st and spun out, I tried to hug the right side for a new fresh line but that didn't work out.
I had the drawbar at 20" but stock length. Will a shorter drawbar help based on what you saw? Tires had 8 psi.
Around the pits I think I had the only stock drawbar setup. Plus most of the tractors had the air filter disconnected. It wasn't dusty but I can't imagine running no filter.
[TUBE]http://youtu.be/w-qprcLaJt4[/TUBE]
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 8:11am
it bit real nice on that pull! it sounds like you need to play around with the drawbar length now to try and maximize your leverage. your on the right track,it's trial and error til you get it right.  and don't forget to video it for us.Smile
This page was generated in 0.099 seconds.
