Wd rmps
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Topic: Wd rmps
    Posted: 20 Aug 2012 at 5:41am
My wd doesnt get nearly the high rmps it should. Took the governor off and I think the trust bearing ( I think that's what they are called) are shot. I shook that metal piece that slides between the wieghts and the bearings rattle. Also the larger piece that the bearing rides on is worn badly in a spot. The worn spot is like the texture of a very bad brake rotor, like steel on steel. What should I replace?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 6:44am
Probably a new governor spring/plunger. What is your top RPM no load with the governor adjusted properly???????????
