Swather or Disc mower
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Topic: Swather or Disc mower
    Posted: 15 Aug 2012 at 8:33pm
My swather is shot and looking at getting a different pull type swing tongue.  I started looking at the 3 point disc mowers also.  I've never been around one.  Any recommendations on either. Is there any brands to stay away from. I have around 10 acres of alfalfa and also mow some brome waterways.  We rake the wind rows together, so would be raking either way. I currently use a sickle mower for the brome. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 9:10pm
Disc mowers are great for mowing, you'll never use a sickle mower agian.  Kuhn makes JD and new hollands.  I like our 275 JD, but it takes a good size tractor set out wide to ballance the load hanging out there.  At least on our hills.   Andy
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 9:54pm
Ditto on above.  Once you use a disc mower, you will never go back to a sickle
Thanks
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 10:20pm
Discbines certainly are nice.  If you miss a sliver or are cutting a wedge you can re-run a row without clogging guards.  Also in downed hay they seem to lift it and cut it when otherwise it would just lay under the guard.  The only downside I have found so far is they demand horsepower.  Normaly I cut with a 9' AC haybine and the 185 doesn't even know it is back there.  When I borrow a 10' New Holland discbine it knows.  Flat land I can cut in 6th no problem, but on our big hill I have to go down to 3rd to hold rpm's.
Edited by Michael (WI) - 15 Aug 2012 at 10:20pm
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 11:44pm
I bought a new Hesston 1345 12' hydro swing disk cutter several years ago, best investment in haying equipment I've ever made.
My cousin in Ohio has had two New Idea 9' diskbines.  He mostly runs JD but likes the New Idea better then the green ones, say's they are quieter.  He bought the first diskbine maybe 15 years ago.  Had a field of grass hay 6' tall that had fallen down.  His NH haybine would cut for 20 feet and plug up.  He called the dealer to bring out the diskbine and after making two rounds at 5 MPH, told the salesman he'd take it.
Edited by JohnCO - 15 Aug 2012 at 11:45pm
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 4:34am
Try a Drum mower, it has less moving parts than a disc, and costs way less.  Google Carter equipment, Tennessee.  My 5-1/2' drum mower was about $3K, 4yrs ago.
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 6:52am
I have a nh617 9 ft disc mower that I operate with 185. Mows about 200 acres of hay and pasture a year. I love it. Tractor handles it well mowing. Transporting you need to use your noggin. It is heavy. Do not raise or lower with the mower pointing it down hill. I mow in second hi. Would go faster, but ground hog holes or blow holes are hard on my systm. Not worth it. Bill
This page was generated in 0.508 seconds.
