wd pto seal
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: wd pto seal
    Posted: 14 Aug 2012 at 5:16pm
Can you remove the pto seal with out taking the cover off?
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 7:01pm
Yep, if you got the right tool. Drill a small hole in the outer edge of the metal and screw a sheet metal screw into it. Grab a hold with a slide hammer tool and tap it out. Best drain the lube out first or you might have BIG wet slippery spot on the floor or drivewayLOL
 My little slide hammer tool is a vise grip. I take the screw out of the handle and put in a piece of threaded rod about 18 inches long. I have a piece of 2 inch cold rolled steel about 3 in long with a hole in it that I put on the threaded rod for a slide hammer and weld a nut on the back end of the threaded rod.
This page was generated in 0.062 seconds.
