WD-45 hydraulic problem
Adam12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam12 Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 hydraulic problem
    Posted: 21 Dec 2009 at 6:40pm
I own a 1953 WD-45 that I have a 3 point hitch and a blade that I move snow with and when I go to lift the 3 point and blade to stack the snow higher the three point won't go up unless I pull forward and push the lever down and back up again, it also lifts the 3 points slow most of the time. I have already moved the flow control screw all of the way out. Any help would be greatly appreciated!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2009 at 8:13pm
It sounds like the valves inside the sleeves are sticking some assuming your linkage is putting pump in full lift mode.The screw your talking about is the one down in/on front of pump body right?If external linkage is correct it's possible to have wear issues inside control linkage housing on back of pump but I'd go there last.Does it get better as is warms up?First easy things are double check linkage setup and change fluid.When draining be sure to take the 1/8in plug out off rear hsg to get it all.My 45 does same thing sometimes but always when cold.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2009 at 8:31pm
You could try moving the hydraulic lever to the lift position, put the tractor in neutral, set the brakes, dismount the tractor and try to move the linkage manually.  If it raises by moving the pump linkage manually, it`s a linkage problem.  If it doesn`t, it is more than likely a pump problem.  Make sure it is full of hydraulic oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam12 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:03pm
I tried changing the fluid and adjusting the linkage, niether of which worked. I did notice that they work fine until a load is applied, it almost acts like it is relieving all the pressure when you apply a load to the hydraulics while they are trying to lift.
ScooterBuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScooterBuck Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2010 at 10:53pm
You could have a hydraulic cylinder packing starting to leak past. That would actually get worse the warmer the fluid gets. Does the blade leak down if left in the up position?
This page was generated in 0.043 seconds.
