5g 6g similar?
ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Topic: 5g 6g similar?
    Posted: 09 Aug 2012 at 1:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 1:16pm
ok what just happened??!  My question is are the 5g and the 6g similar machines?  What parts will interchange? Thanks for any insight on this.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 4:02pm
The transmission,stering cluch,final drive and undercariage are interchangable
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 6:30pm
If you take the tractor from the transmission back , all HD5 and HD 6 parts interchange. Track links , sprockets, rollers. idler and other track parts but each machine uses more or less links in track.
 counter weight, also interchange . HD5G was a 1 yard machine HD6G a 1 1/4 or 1 1/2 yard machine .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 8:03am
thanks for the info.I found out from the guy that has this machine that it is actually a hd6g serial # 1898 my guess is its a 55 or 56? Anyone know what year this one is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 9:48pm
1956    ser #      1147-6465
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 5:53pm
Later HD-6's had many differences from the HD-5.  Undercarriage parts are mostly interchangeable for all models.
