C oil pressure port.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: C oil pressure port.
    Posted: 09 Aug 2012 at 1:10pm
Does a C have an oil pressure port on the left (manifold) side?
I want to install a oil pressure switch on the left side to activate a qizmo.
I don't recall one, just the block coolant drain.
I am stationed away from the machine, so I can't just go and look myself.
Thank you.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 2:14pm
No! You would have to tap in where the pipe comes out of the pump on the right side.  There is not an oil pressure channel in the block at all in that type of engine with that type of pump.
