Changing a Grader Tyre
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Topic: Changing a Grader Tyre
    Posted: 09 Aug 2012 at 5:14am
The motive power is a FA 10.  The quick drop valves make it work as a hammer.  The frame is easier to move around than the wheel, and, when turned up, helps get the wheel centre out once the beads are loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 8:49am
I took a old rim and cut a slot across it so the rim expanded slightly , then use that to let tire fall onto when de-mounting tire.
 Backhoe bucket worked well for most tires - until I ended up putting tooth through sidewall on one of my 13.80 x20 float tires on dump truck.
 Those old tires seems to want to stick to bead area .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 4:14am
Coke,
When they look like this
they're a problem.  We had to get the matching one off to get the grader home.  Had to chainsaw the wheel centre out and oxy the beads off.  I'm pretty happy that this rig got this one loose.  Saved all the tubes as well.
Scotchenomics on used tyres here.  If you don't save the tube you need to buy a new , one which needs a flap or it is likely to split on the seam somewhere.  Add about $A200 or so for this, plus cost of a second hand tyre very quickly comes close to the about $A600 for a new Chinese tyre, tube and flap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 5:12am
Looks like you got all the goody out of that one!   You could almost see the air inside while inflated and tell when it was going bad!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 5:24am
DMillar,
We inherited it like that.  The good was got a ling time before!  Did its bit foe CO2 when we burnt it though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 11:49am
When I got my Adams 411 grader I got 4 extra tires with it , only problem was those tires were mounted on dayton open center type rims where the Adams had a solid center rim that bolts to hub.  I also saved the tubes by having new valve stems vulcanised onto old tubes .  One front tire I have a liner in it as sidewall has a few weak spots .
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 1:50am
Gidday Ian; had a mate with simila problems with a scoop tyre.
They used a rockbreaker to impact it off
Just another idea !
cheers merv
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 2:57am
Merv,
My father had a quote which went
"Do the best you can with the material in hand"
Or as  friend back from a stint in the NT in years past reckoned
"Necessity is the mother of invention and the father of halfcastes"
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 12:42pm
that is neet
