wd has no spark?
hddlh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hddlh Quote  Post ReplyReply Direct Link To This Post Topic: wd has no spark?
    Posted: 29 Jul 2012 at 9:16pm
my wd has no spark.  it's been sitting for a number of years since last run and ran fine when put in shed years ago. wanted to get her going, so replaced gas, oil, plugs and battery.  turns over great but no spark.  no experience with magneto's, what should I be looking for?  thanks for any help
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:41pm
I don't know which mag you have, but remove the dist cap and mark the position of the rotor. The remove the mag cap and look at the points. You can run a little fine sandpaper through the point s to clean them, then use a small piece of pasteboard (match book cover, cereal box top) run it throught the points to clean away any grit. Reassemble and check it for spark. Some of the mags will lose time when the cover comes off, others will retain their time, it depends of the model. LOL Bob
Edited by Chalmersbob - 29 Jul 2012 at 9:42pm
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote hddlh Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:51pm
my wd has a fairbanks mag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 7:25am
As Bob mentioned, depending on the model of the Mag, the model "J" will be taken out of time when lifing the lower timing cover to service the points. If its a "K" model F/M or and "X" model, the timing gears are part of the breaker plate so you will be okay. The "K" series which came on some of the WD's, has a single rectagular cap. The "X" is similar to the "J", but there is no timing gear on the cover side, so nothing to take it out of time. The contacts probably just have oxidation on them from sitting. A little tuner cleaner or Brakekleen works best without filing the points. When you file points, you remove the Cad plating off of them and in the future when wanting to use the Tractor, you'll be faced with the same problem again, but worst. The tuner cleaner or Brakekleen will clear away the oxidation without the need to file anything. If its a "J" Mag, you need to re-align the timing marks again in order for the engine to fire right up again. Look at the tag that's on the Mag (if still riveted to the unit) It may say "FMJ4B3" It would probably be a good idea to renew the lower cover gasket. That's why the moisture got in there in the first place. HTH
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 9:02am
The oxidized points are the most likely, but if the impulse isn't kicking that will prevent spark while cranking.
Gerald J.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 10:11am
I just clean the points with a dollar bill. Won't file off the plating but does remove the oxidation. Kip
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 10:40am
Problem with using dollar bills... is that they're gettin so hard to find... anybody found a good supply lately?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 10:46am
Especially hard to find here in Canada as our dollar bills were replaced by the "Loonie" coin!!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 8:19pm
I've heard that $1000 bills work also.  Smile
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 10:03pm
The first thing I would do is determine if it has a kill switch hooked up to the Mag. If there is any wire going to the mag other than plug wires, disconnect it for now and try getting spark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 6:29am
Its pretty tough to find a $1000. dollar bill around here, never mind to use to clean off points! A buck is a little easier to find, and like Kip mentioned, that works also to clean off points!  LOL! An old trick, but still works...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 12:23pm
Good cotton bond paper works, like letters from lawyers.
Gerald J.
