hi/lo on WD |
Post Reply |
Bill_MN
Orange Level Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1463 |
Posted: 29 Jul 2012 at 5:03pm |
is it possible to put a sherman or some other hi/lo on a WD or does it only work on the WC because of the lack of hand clutch? I would like to have a little more speed for tractor rides since I'm usually running wide open and just barely keeping up, would like to keep stock tire size
norm[ind]
Orange Level Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
instlla SP100 COMBINE SPRING WILL NOT HURT TRACTOR EITHER
norm[ind]
SORRY INSTALL WAS TO BE THE WORD an a-c service man gave us one yrs,ago for the other colors to make them mad never took a rear seat MOVE OTHER FOR THEM
AC WD45
Orange Level Joined: 28 Sep 2009 Location: Mid Michigan Points: 1995 |
^ huh?
German Shepherd dad
1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193 |
Richard
Silver Level Joined: 12 Sep 2009 Location: Springfield, IL Points: 198 |
The last tractor drive I was on with my 45 I was running wide open and got left in the dust. That's not my idea of a tractor drive.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22818 |
If everybody did like our club did, you wouldn't have a problem. A stock WD45 was first in line and instructions were to follow that guy and keep some space between tractors
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
Bigger tires would be the easiest way to get more speed, the WD45 driven back from Ashton ID to Rolog in about 95 or 96 had 38's on it and went 18 MPH
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20186 |
A WD45 with good 14.9 x 28 rear tires is supposed to do 12 mph at 1400 rpm which would translate into 14 1/2 mph at 1700 rpm wide open throttle. If you put a D17 governor spring/plunger in it, the engine speed will increase to 2000 rpm and ground speed then will be 17 mph.
Post Reply | |
