Looking for special tool |
Post Reply ![]() |
JimWenigOH ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: NC Ohio Points: 1153 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jul 2012 at 4:10pm |
Anyone have the special socket for the Gleaner 9/16" feeder beater fingers, AC TP 1007, that I could use or buy?
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8089 |
You can cut a deep well socket in two and weld a length of pipe in between. I just worked through the inspection holes with a hand wrench.Put a little blue loctite on new ones. Can't remember if I was able to get a box end over the end with the guide out or not.
XT in pa ![]() Orange Level ![]() ![]() Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
i used a pipe wrench but i replaced it and the new one had a hex at the top it was 5/8 on f2
190XT,D17and 7045
Never mind. My new fingers are 5/8" with two flats at 1/2" wide on the end, and I don't know if it would use the same tool as the 9/16" fingers. I will grind out a 1/2" square socket to work.
Post Reply ![]() |
