WD45 Loader goes up don't go down
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Loader goes up don't go down
    Posted: 25 Jul 2012 at 6:48pm
I got the hydraulic hose on my WD45 rear lift cylinder tonight and filled it with oil so I could try the lift and try the loader. The loader came up first then the lift arms. When I pushed the control lever down nothing happened. Even with the lever down it still sounds like the hyd pump is still pumping. With the motor turned off I checked all the linkages and everything is moving as they should. an adjustment could be needed but everything is moving. It doesn't have a friction block on the quadrent so I can feel 3 positive stops when I move the hyd lever. Any ideas?Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 8:26pm
I just wanted to add that the rear lift doesn't go down either. I've been looking at the IT book and I think it's a problem with the hold valve. I've adjusted the linkage and the control valve screw but no luck yet. I'm afraid to drive it until I can get the pump to stop. Should I pull off the hold/control valve and clean it up? can parts be bought got the pump or valves?
Larrywdin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larrywdin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 9:38pm
I had that problem once, and it turned out a roll pin came out of the back linkage inside of the relief valve mech...
I'd post a picture, but I don't have it handy right now,,,
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 9:43pm
it could be a plunger in the pump   i had this happen once i pecked on the pump with a hammer and its been working now for about 15 yrs.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2012 at 8:53am
When it happened to me it was due to a sheared bolt in the in the Traction Booster linkage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2012 at 3:59pm
I see linkage from the tb to the valve on the pump that has a long slot. I assumed this slot would slide on a pin but I need to go look to see if this is just an adjustment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2012 at 4:29pm
I have read posts about screwing the front screw on the valve, all the way in and out a couple times to cure that???? Can't find the post now.
Edited by CTuckerNWIL - 26 Jul 2012 at 4:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2012 at 7:01pm
Thanks Charley. I'll try that this weekend. I need to let the loader down first to let the pressure off. Will the screw come all the way out or does it stop? When I get it working right I'll change the hyd fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:23am
I have unscrewed the screw several times and tapped on the valve with a brass hammer I've unhooked all linkage and wiggled all the valves and still nothing. I noticed today that if I put alot of weight (me) on the 3pt it goes down and the loader goes higher and when I step off the 3pt the loader goes back to where it was. The pump still never quits putting out pressure when it's running.Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:27am
One more thing. I can unscrew one of the plungers on the end and it would let the adjustment screw come out further. Would it let it unscrew all the way out? Should I just remove the pump and rebuild?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 9:46am
I would guess the unloading valve plunger is stuck. probably have to take it apart and clean it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 1:00pm
Charley I snuck out to the shop for a few minutes and broke the 2 bolts loose that hold the valve on top. I wiggled it loose and still nothing happened so I know that the plunger in this valve is stuck. I'll pull it off as soon as I get a chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2012 at 1:48pm
Update the adjustment screw in the valve on top was bent on the small area that goes inside the spring. I put it in a vice to straighten it and it broke off very easy. I need a new valve or the adjustment screw. I was able to retrieve the check ball with a magnet.
