Question to Coke and Hector Gemme
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Question to Coke and Hector Gemme
    Posted: 25 Jul 2012 at 11:13am
You fellas know I have a HD7G, what are the differences from mine to a 7G-B?  I have seen one from a distance and it looks 'similar' but different, like segmented drive sprocket and single upper guide roller.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 12:07pm
The hd7g has a 4 cylinder motor and the HD7GB has a 6 cylinder motor d3500 and  have a HD11 track and special idlers and  segment sprocket
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 2:07pm
Thanks Hector, do the machines (7G and G-B) share the same style final drives/housings?  If they do I wonder if a sprocket center from a 7G-B would work on a 7G?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 2:24pm
The HD7GB sprocket center should fit but the outside sprocket is smaller with 5 segment 5 teeths and the 7g should have 27 teeths and the track frame is 't the same and should have 1 or 2 more rollers on 7GB
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 2:28pm
Thanks Hector, this may be a starting point to putting an 'other' manufacturer's (Cat) rails under my 7G.  I was looking for a better alternative to custom building a sprocket, the 7GB part might be a starter for me to look at.
This page was generated in 0.162 seconds.
