AC 7060 fuel pump question
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: AC 7060 fuel pump question
    Posted: 24 Jul 2012 at 7:58pm
Went to start my 7060 and it would turn over but nothing but then realized that i had not pulled the injector pump shut off out but it still would not start then i primed the pump with the plunger and it took right off but sorta had a miss for a few seconds the tractor had set for about 2 weeks without starting as well. Is my pump getting weak or? Any thoughts ? If you have a question just ask thanks
Alan (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 8:24pm
Sounds more like air in the fuel resulting from a leak or bad check valve.  The stumble was probably due to some trapped air in the lines.  Do you see/smell any diesel fuel leaking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 8:27pm
Originally posted by Alan (C-IL) Alan (C-IL) wrote:
Sounds more like air in the fuel resulting from a leak or bad check valve.  The stumble was probably due to some trapped air in the lines.  Do you see/smell any diesel fuel leaking?        Yes its got some leaks on the fuel pump would that cause this?
Edited by AC 426 power - 24 Jul 2012 at 8:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 8:34pm
yea, diesel fuel systems don't like air and when you lose your prime, its a pain to reprime them... Sounds like you got lucky and it primed up easy.  If you have a diesel leak, it is very likely that air is getting back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 8:39pm
Alright thanks for the information
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 9:48pm
Take the primer pump apart. There is 2 check valves that could have foreign materal in them not letting them seat.  MACK
