hd 6g final drive
ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Topic: hd 6g final drive
    Posted: 24 Jul 2012 at 7:30am
Does anyone have a picture of the puller used to get the outdrive bearing off of the shaft on the final drive? the one mounted to the truck frame outside the sproket. Thanks
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 8:44am
my dad use to cut the truck frame  with a torch   and knock the bearings out and reweld it back to the frame.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 4:41pm
i hope this helps. it is from a hd5 service manual burt they are the same bearing and housing. good luck
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 9:49pm
The two bolts on the outside screw into the housing and the center bolt pushes it off  We use a 10 ton hyd puler kit for all those jobs
John
15 allis chalmers tractors
9 lanz bulldog tractors
2 water cooled deutz
9 john deeres tractors
14 Aus made orange chamberlains
I spent most of my money on old tractors I wasted the rest
This page was generated in 0.258 seconds.
