SAE 80 EP ?
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Topic: SAE 80 EP ?
    Posted: 23 Jul 2012 at 5:17pm
I recently added a D19 diesel to the stable . I am going to change all of the fluids. The operators manual calls for SAE 80 EP for the transmission and final drive. Is this the same as 80w-90 gear oil? I know oil specs have changed since the early 60's and was thinking its the same but thought I would ask to be sure. Thanks in advance.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2012 at 8:27pm
It will work fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2012 at 8:28pm
anybody?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2012 at 8:32pm
EP stood for Extra Pressure, hence to make sure there was still a film of oil between the gear teeth from the torque. Due to the oil chemistry we have today there are additives that eliminate this designation. Todays 80/90 weight is the replacement.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2012 at 8:47pm
I would have used the 80/90 and never thought anything else about it, but today when I was at the Rural King there was a SAE 90 EP oil that said hyd/trans and said ford in parenthesis. I thought it was worth asking about . Thanks for the help.
BigPuma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigPuma Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 7:12pm
Just got my hands onto my fathers D17. It rarely gets used, and will basically be a "tinker toy" for me to fix up, and rejuvenate... Getting ready to drain and replace fluids. Opinions on synthetic fluids instead of conventional? It will probably get less than a few hundred hours a year unless I roger up for the elder farmers around here. And even then it won't be many hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 9:17pm
Put hydraulic wet brake -821-universal hydraulic. Don't use that heavy stuff that don't get in bearings in cold weather.   MACK
JJ_ncOhio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJ_ncOhio Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2017 at 9:33pm
I just did this when servicing planetary finals on the rwa axle on my combine. Manufacture wanted 90ep, can't find that product anywhere. Google search says Castrol makes it; appears to be readily available in Europe, not in continental US. Ok, so what to use as a substitute? I used Scheiffer's 75w90 synthetic. I recommend you use a synthetic also.
Here's the deal, 80w90 has additives. Those additives are designated on your container as API rating (GL5, GL4,....ect) API GL5 meets military spec. Each rating refers to the additives in that particular oil. Problem with additives some are corrosive, caustic, to yellow metals (brass, bronze, ect....) I can't say because I haven't had a D19 rear end apart, nor have I broken into the finals on my rear wheel assist, so I can't say that there are yellow metal shims or whatever inside the gear case. Nor do I want to find out with the expense of replacing. Part of the "engineering" in synthetic oils is uniform molecule size, as well chemical make up not needing additives.
Like I was saying I went with a synthetic and feel safe with it. I saw this thread and thought I might chime in, certainly not an expert, just recently went through the same process as you.
Hope this helps
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 6:17am
I'd go with 75W-90 synthetic also. It will work better than the old stuff and it flows better in the extreme cold.
tractorhead9542 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 8:38am
You may run in to a leak horse. Synthetic oils will come in and clean out sludge and seals and 'relax' them. Unless overhauled with new seals, I do not recommend it. I have been in heavy equipment for 20 years and have seen this happen several times- automotive and off road
The road to nowhere...leads to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigPuma Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 9:12am
Yes I also work heavy equipment for a municipality. The service schedule is pretty strict so we don't have too many leakers... The tractor has sat for a few years with only occasional starts. I plan on going through it this winter
Also, thoughts on Lucas additives? I've had good experiences with it in the past, but it's been in the automotive side and not agricultural equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 9:26am
Look I am a firm believer in synthetics. But I do not and will not run it in anything pre 1988 unless overhauled (automotive). They will leak! And I found it to be true that Engines & Transmissions designed to take straight weight oils do not like multi viscosity fluids and have found evidence with bearing failure due to oil break down and overheat.
I wish not to upset anyone but I have spent many years replying to the questions and comments label and or calling the phone numbers on the back of products to receive more information. I'm kind of a dork when it comes to fluid analysis. More expensive generally doesn't mean better in fact the oil that Tractor Supply sells is the same quality as high end brands.
Everybody has their own preference and 'doctored up 'mixture to feel good about, even myself. I have always felt if you need to add something to your oil to get it to run right, you are prolonging a problem. There are additives to help cool oil and add lubricity and that's great. But we all know that these machines have been in service way longer and have way more bearing wear than what a little bit is synthetic additive will help now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 11:18am
The problem of synthetics causing leaks was solved in the 1970s. Shade tree mechanics just keep passing folklore down from generation to generation. We're not talking engine sludge in a transmission. If I have sludge in my engine I'm going to run a high detergent cleaner first, with appropriate filter changes, anyway.
Edited by DougS - 04 Sep 2017 at 11:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 11:20am
And then you will get leaks anyway DougS
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 11:23am
Who got you so accusatory and upset. Take it easy.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 11:38am
Common leak problems with the synthetic oils is the use of permatex instead of a proper gasket. The synthetic oil will eat the blue goo and cause a leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 11:43am
Very true and poor rubber parts (usually aftermarket) from overseas seem to be an issue.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 12:13pm
Even in the 40's and 50's they had what we called detergent oil.  We found in machines that had not been recently overhauled that using detergent oil could cause leaking and oil burning.  It took the crud away that kept the oil from burning or leaks.  Got quite a few more hours on the engine till overhaul.
If you have a unit like Big Puma's D-17 that is just used for "tinkering around" and you have no plans for an overhaul then use the non detergent oil.  You will get more hours without problems.
In the hydraulic compartment use non detergent 20 wt oil.  Even though I have heard excellent reports on the use of the newer transhyd oils I have heard they can also cause problems with seals leaking in older units.  Older seals may not be used to the chemicals in the newer oils.  If you have recently overhauled the transmission or rear ends and replaced the seals use the newer oils by all means.  They really are better.  However,
my thinking on the older non overhauled units is use the originally prescribed oils or thereabouts.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2017 at 4:01pm
Any of the RTV sealers that smell like vinegar are bad choices for any sort of automotive use. Over time they will corrode metal and are not particularly suited for petroleum oil environments. A much better choice is Motorcraft TA31. GM also uses a very similar sealer.
amx1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amx1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 6:17pm
Just curious, I have a 1963 D-19, the AGCO salesman sold me the GL4 (AGCO brand) multi for the power director and hydraulic , it states semi synthetic, he said it would be safe for my tractor, but I should still use the 80-90 in the final drives, , what's you opinion on that, Thank You, Pete
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2018 at 8:22pm
Leaks are just a downward spiral of old equipment. I suggest diapers myself. Lol
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 9:59am
exactly what I did with my D19 twenty-six years ago and no problems and in the early 90's it was my heavy tillage tractor. That is what 190's eventually went to and it's the same basic transmission as a D19. 7000's too.
Wink
I am a Russian Bot
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 1:07pm
I know Mack's knowledge and reputation. If he recommends it, that's what I would (will) use!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:07pm
821 is a universal tractor hydraulic fluid. 90 weight will destroy that power director in the cold and make the tractor creep even out of gear. Most stores list what you need as tractor hydraulic fluid, TCH or THL.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2018 at 8:15pm
It Depends!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2018 at 9:07pm
Leaks are guaranteed on relaxed seals and usually in older equipment. It's not something to throw the flag up and walk away from. That's just the way it is. Fix the problem or problems and you're fine. It's just something that you have to deal with with older equipment.
This page was generated in 0.099 seconds.
