Wuakesha B engines
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Topic: Wuakesha B engines
    Posted: 22 Jul 2012 at 6:46pm
Were these motors used in any other tractor or application? Does any one have a mag or spare motor for an early B for sale? Any help would be appreciated.
Thanks Luke
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 6:53pm
  yes CASE USED THEM ALSO  vi
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 8:22pm
I assume the Wak motor has a piston fire every 180 degrees, even if the order is different. Seems llike there would be several FM mags that might work.
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 10:06pm
i know oliver used waks
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
