hd 6 g serial #
ratchet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Topic: hd 6 g serial #
    Posted: 19 Jul 2012 at 9:27am
I need assistance identifying a hd6g I just purchased. There is a plaquard on the dash that has hd6g-16378, and on the right rear of the machine stamped hd6g 1637 any help idemtifying this machine would be appreciated, also i have a hd6g 1956 model are the parts interchangable??Confused
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 12:03pm
Yes must parts are the same in the 2 machines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 1:13pm
I suspect you dig a little harder at the rear and that '8' will come up, too close a number on both to not be the same.
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 4:36pm
That "8" could be a worn off "G" also....... If it has a 344 engine its likely a 1637 s/n, if it has a 6000 engine its likely the higher s/n.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ratchet Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 7:28am
Its a 1963 model the higher serial # Thanks for all of the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 11:50am
 The HD6G later serie the head motor is different and should have a crossbar betwen the 2 finder and the hydrlic hose are attache on and for changing the stering cluch you need to drain the hydrolic tank and removed the cylinder hoses and crossbar.
This page was generated in 0.367 seconds.
