Wd45 ignition hook up
davidk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidk Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 ignition hook up
    Posted: 03 Jul 2012 at 3:50pm
Does the points wire go to the + side of the coil or the - side? Or can it go either way. Mine is hooked to the - side but I have seen it hooked to the + side too. Thanks Dave
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 3:57pm
Depends on if you have positive or negative ground. If you have a positive ground you connect your ignition wire to the - side and the positive side to the distributor. If negative ground the opposite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidk Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 5:08pm
Thank you for your response.
