wireing an altinator D17
don slick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote don slick Quote  Post ReplyReply Direct Link To This Post Topic: wireing an altinator D17
    Posted: 28 Jun 2012 at 8:27pm
Have a 17 that has altenator that was not wired. Does anyone have a pic and do I still use the regulator which still has wires on it? I think it should have a built in regulator????????? Don
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 8:37pm
Don     do you know what kind of
alternator it has on it ? or a picture
would make it easier to help
B:-)      Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote don slick Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 8:39pm
It has a Delco altnator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 8:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 8:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote don slick Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 9:30pm
So I do get rid of the voltage regulator under the gas tank....Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 6:28am
If you're going to use an internal regulated "SI" series Alternator, you would remove the OEM VR. If your Alternator is the older style "DN" series, then you would use the OEM VR in conjunction with the DN Alternator....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 7:45am
If you are using the SI Alt be sure you wire the key into proper position in the circuit or you will find the Alt will produce voltage to coil and you will not be able to shut of tractor.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 9:43am
A purist would wire the remote sense directly to the battery.  It would be a good idea to fuse this wire somewhere near the battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote don slick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 10:37pm
Thanks Guys, I got it all done and works fine. Had some time comsumeing problems, had to find the cracked wires and one broken end that didn't look bad. All turned out fine. Thanks again     Don
