CA differential carrier oil seal
TimAla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimAla Quote  Post ReplyReply Direct Link To This Post Topic: CA differential carrier oil seal
    Posted: 27 Jun 2012 at 7:22pm
I am new here and am learning a lot. I have looked at the parts manual and searched the forum for this seal but don't see it. I need to know the number or something so I can replace these as I rebuild. I have the left side finished and ready to re-install. Any help will be greatly appreciated. My tractor is a 1954. I need to learn how to post pics also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 7:42pm
In my opinion, the best way to post pictures is to open a free account with Photobucket.com or some such photo storing outfit. If you upload to photobucket then go to your picture and copy the IMG Code and paste it in with your text, the picture shows up in your post.
 I actually use Picasa.com because it is way faster to upload pictures to and is unlimited as long as you upload them in web share size. It's just a little different posting them here.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 7:48pm
If you have the old seal you can go to a bearing supply (I go to "Bearing headquarters") and they should have one for you.
Agco dealer has many of the seals, you could call one of them like Sandy Lake, (see adds this site).
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 7:48pm
NAT410163R
I assmume National 410163- same as the B and C
Rear Axle top pinion shaft
Differential seal 1.250-2.004                 .468 lip seal            CR12458
Edited by steve(ill) - 27 Jun 2012 at 7:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimAla Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 5:56am
Thanks for the help. I will most likely need more before done. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 6:43am
Another easy way to post pictures is also using face book , download pictures to that site , then you can just copy them from there and paste them into your post here . Works good as many pictures I post I just use the copy paste , no tag lines and such needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 8:24am
You can do it that way in Picasa and photobucket too Coke. I just right click and click copy image and paste it here.
Edited by CTuckerNWIL - 28 Jun 2012 at 8:24am
