wd45 starter |
Post Reply ![]() |
TomYaz ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: PA Points: 10340 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jun 2012 at 6:02pm |
Starter spins but doesnt engage the ring.
Pulled starter, ring looks fine. When I engage the starter, the gear on it spins, but it is supposed to move forward as well to engage the ring, correct? Well it isnt...
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
That is how it suppose to work!
Can you turn the gear by hand? and resistance?
The force of the rotation should spin it in to engage.
Bob
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Sometimes there is a burr that the gear hangs up on. You may need to use a Dremel grinder to remove the burr.
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6496 |
Sometimes the bendix needs cleaning and a light application of dry film lube. It is probably a burr as mentioned or some grease and dirt holding the gear back.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8658 |
Because it is an "inertia" bendix,it must be free to spiral down the shaft.
Didnt try to spin it manually, it does spin when powered up...but doesnt travel down the shaft. Thanks guys, will check for a burr or the like.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Use some kind of cleaning agent (brake clean, carb clean) to clean the crud and sprinkle some graphite on it. Don't oil or grease the shaft.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12011 |
Never oil a bendix drive! Do as Tuck said. Clean the drive with Brakekleen and dust it with graphite spray. Good to go. If oil starts slinging into the starter motor, you're gonna have a mucky gooy mess inside the motor that you don't want.
Post Reply ![]() |
