XT Final drive bearing
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: XT Final drive bearing
    Posted: 25 Jun 2012 at 5:17pm
is trashed and I would believe that is why the seal let go.
So although I aint the sharpest knife in the drawer, I believe I have to pull the wheel off the axle. Then I can do what I need to do, but still I have the bolt in the bottom of the final drive to deal with. One step at a time. It makes since cause when I drained all the fluids when I got this the left final had only 2 quarts in it.
Edited by captaindana - 25 Jun 2012 at 5:19pm
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 8:29pm
When you drained that side this time then there wasn't extra trans fluid in that side or was the trans just low for some other reason?
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2012 at 9:07pm
Wonder what the inner bearing looks like? Were you supposed to slightly overfill the left side for plowing applications?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 6:02am
Dan that question I keep asking myself! The left final drive had some spider cracks which we sealed with jbweld. I topped it with 2.5 gals last fall and it never leaked. So after draining trans oil and pulling rear pto, I see the trans [new] oil from last fall is yellow from water. It had a ton of water in trans when I drained it. The oil which leaked in the field on the steep hill was not trans oil cuz it wasn't yellow. Why the trans oil was low I am guessing when I refilled it and drove around some pockets filled and it probably lowered to just not quite touching the bayonet. I have to get the fully weighted wheel off, then I can see to fix bearings. As I said that bolt in the final drive drain is still an issue. Jeepers I don't have many tools big enough to mess with that wheel; ugh.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 6:36am
I have confidence in you - be back up and running in no time - is that wheel heavy, LOL
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 10:22am
Capn; it's always nice to have a good excuse to buy more tools!!  Then you can 'get er done'!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 11:33am
Hey capt found a hand pallet jack like the ones used in wharehouse and semi trailers, works to move tires and wheels in and out once you have them loose. just need a concrete surface or a few sheets of heave plywood to work on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 4:47pm
BTW when I was looking at this tractor pre buy the guy said his dad had fallen asleep and drove through a stone wall fence and cracked that housing. I am now thinking that bolr coming out cracked it. I was investigating the cracks when we jb'd them and kept telling Ian the crack was made from the inside outwards. I now believe I was correct. My immediate issue is getting the wheel off the axle. There are 3 bolts holding the hob and my buddy says they never want to come apart.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2012 at 6:17pm
You're going to need those special pusher bolts (jack screws) to get the axle hub off, if you don't already have a set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2012 at 3:53am
Yeah I have been studying what needs to be done here. But for the life of me I can't see how any 1/2x1 bolt can get into the final drive assembly but its there and I will figure this out!
This page was generated in 0.820 seconds.
