CA Pipe Frame Loader
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: CA Pipe Frame Loader
    Posted: 16 Jun 2012 at 11:33pm
Anyone modify the lift cylinders for the CA -8 Pipe Frame Loader to High Volume Low pressure as opposed to the original lift cylinders that were low volume high pressure.  Am looking into a design change and too add a PTO driven hydraulic pump.
Would appreciate your insights on the CA Pipe Frame Loaders.  I would like to make the loader full hydraulic rather than having a trip apparatus to dump the bucket.
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 6:22am
I checked the machine over last night, it has a really nice original snap coupler system set up on it.  Balance of tractor is there minus the carb and starter.
What is the going rate for a parts CA Tractor with a CA-8 pipe frame loader.   Loaders cylinders are all the way out and oxidized so was thinking that if one were to use the loader, it would be better to convert to high volume low pressure than try to rebuild the old high pressure low volume loader cylinders.   I am thinking the value of the tractor is slightly less than $500 given no carb, and no starter but would appreciate your thoughts.
 - Thank-you  Orangeman  BTW Happy Fathers Day - maybe I should get this as a fathers day present. LOL
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 8:29am
Converting from one hydraulic pressure/volume range to another, seems like it'd involve lots of complicated math, but it is simply a matter of determining displacement.
If the current system is operating at 3gpm and 4000psi with a pair of 1" bore cylinders having 30" stroke, and you switch both to a 2" cylinder, you'll be dealing with
1" cylinder has 0.5" radius... multiply 0.5 * 0.5 * pi (3.1415) = 0.785 square inches of piston area... multiply that by 40" stroke, and you'll have a total displacement for one cylinder of 31.415 cubic inches... divide that by 231 (cubic inches per gallon) and you'll have 0.135 gallons required to make the entire stroke for that cylinder.
Same math on a 2" diameter cylinder, with a 3.14 square inch piston surface, it takes 125.66 cubic inches (just under half a gallon) to extend a 2 x 40 cylinder... so going from a 1" to a 2" cylinder requires about 3x the fluid.
If you've got 3gpm available at 4500psi running the stock cylinders, and you're changing to cylinders that use 3x the fluid, you'll need to go to a pump that has 3x the VOLUME output... so 9gpm... to get the same extension velocity.  You MIGHT need to go up a hose size so that you won't have flow restriction.
Now, as far as pressure is concerned, you'll be going from a 4500psi system down to around 1500psi... there's really no NEED to do the math for this (because you'll have substantially more surface area), but the concept is simple... known pressure against a known surface area results in a calculatable force.
If you have 100 psi acting upon 1 square inch of surface area, you'll have 100 lbs of thrust.
If you have 4500psi acting on 0.785 square inches of surface on the existing system, you'll be seeing 4500 * 0.785 = 3532 pounds of thrust.
If you have 1500psi acting on 125 square inches, you'll see 4710 pounds of force.  Clearly enough, if not excessive, in comparison to the older system.  The best way to solve the situation (prevent breaking something) would be to dial down the pressure relief valve so you're down around 1100psi.  The pump, valve, cylinders, and loader will be happy there.
Now to add the hydraulic curl function, it's just a matter of fabrication, adding a second valve section, and doing some simple math.  If you use the same BORE of cylinder as the mains, your extension/retraction velocity will be same as the main lift rams... but the curl rams will obviously take less time simply because they're shorter.
The only 'gotcha' is that the piston ROD occupies the RETURN side (retract) of the cylinder, and it has much less surface, hence volume, due to the presence of the rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 9:24am
Good Morning Dave:  Excellent tutorial on cylinder hydraulics, very appreciate for your insights.  After reading maybe I should keep the cylinders as is and get new rods in place of the oxidized rods and make some minor improvements.   I am interested in the CA as it has a small footprint and with the loader will allow me to work in tight spaces on the tree farm.
If I do convert to a low pressure system would it be better to run the new pump off the PTO or the crankshaft with a coupling?
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 9:55am
Even though you've got some semblance of "live hydraulics" with use of the hand clutch, I'd still go with a crankshaft driven pump like I did on my "B".
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 4:43pm
Steve: Did you have to fab a special cowl and bracket to use on your B tractor?
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 6:08pm
A 12V electric pump could also work. They are available in single acting and double acting versions and come with their own resevoir and controls. The ones I have have about a 1 1/2 gallon resevoir. Have not tried it out on the loader, but they pick up the wheel disk and raise my tilt bed trailer (3" piston) just fine. I got mine off Ebay. Easy to install.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 6:26pm
Greg L. - thats a very interesting concept you have r.e. electric/ hyd. I have a old lift from a snowplow, and am now wondering what possibilities it has  would need more oil capacity and a big alternator if used much.  Orangeman sorry to sidetrac your post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 12:07am
Steve's point about getting 'full live' off the front of the crankshaft is a very good one.
I haven't looked at a CA up close, but if it's same as my '48B, I would probably find a way to put a second pulley-belt on the front of the engine and put the hydraulic pump on one side somewhere.
Using an electric pump seems like a clever idea, but when operating a loader, you'd be operating the pump ALOT, which chews up lots of battery power.  You'd need to come up with a WHOLE LOT MORE charging capacity, and battery... in order to work for any long length of time... and most battery-electric hydropower packs aren't in the 9gpm range... they're more like 2....
The rams... if they're corroded, scrub 'em with some brass wool and see if they clean up... they're probably chrome plated, and if so, might not be as bad as you think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 2:05pm
Orangeman, here's a pic (I hope) of my installation on my B.
I mounted the aluminum on the rad support and the shaft extension goes into the black pipe spacer where the Lovejoy coupling connects the crankshaft extension to the pump .
The lovejoy takes care of minor missalignment and has worked for going on 10+ yrs. now.
I'm looking at an installation for my CA. the 2 bosses that protrude through the rad. cowl look like great mounting points for the pump and it's adapter.
You need a metal lathe or a friend who has one for the mods to the pulley for the extension shaft.
I have also seen some neat belt driven extensions installations that require less machining.
PM me if you want more info
Edited by SteveC(NS) - 18 Jun 2012 at 2:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 3:43pm
Hey Guys: Wonderful information you have shared.  Really appreciate all the input.  I can see now why Allis came up with the I 40 and I400, with the deeper/heavier grill section with the pump on the front makes for a real nice setup for the hydraulics.
I have a Dynahoe backhoe that utilizes a very similar setup, a big Vickers pump on the front mounted to the main frame which is coupled to the front crankshaft of a Continental F-244 block.
Steve - extra nice job on the pump fab.  I have four CA tractors and can see where the tapped mounting bosses for the cultivator brackets just below the radiator cowl would be really handy to mounted the pump plate on.
The other area on the tractor that intrigues me is the two tapped holes on the torque tube  on either side.   These would appear to lend themselves to mounting brackets on or attaching a hydraulic cylinder to control objects mounted below the torque tube.
In close, all very good insights and hope I can return a favor sometime.   Orangeman
