WD 45 Diesel Block
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Diesel Block
    Posted: 16 Jun 2012 at 9:03am
I have a friend that needs a good engine block for a 45 diesel. Any leads in the Pennsylvania area would be greatly appreciated.  Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 3:18pm
There are 230 engines on older Gleaner combines ; may keep an eye out, model A i believe
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 5:54pm
I ve got a 45D block but it has a hair line crack between no.2 and no. 3 cylinder if your interested in it call me at 865-850-4538  im located in East Tn.  , If im thinking right I had a 56 model wd45D that had a A gleaner diesel block in it and it will work but you only have one oil filter and youll have to re rig your throttle rod to make it work.
Edited by mark-east-tn - 16 Jun 2012 at 5:56pm
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 8:14pm
I also have a bare block here in CT. It has the hairline cracks between some cylinders as most do. Add me to the list after mark-tn, would like to move it out soon.
