Hauler for HD11B?
Forestgnome View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Forestgnome Quote  Post ReplyReply Direct Link To This Post Topic: Hauler for HD11B?
    Posted: 12 Jun 2012 at 5:14pm
I was wondering what you think would be a good older truck/trailer setup for hauling an HD11B dozer? I've been seeing some good deals on the following: Ford F8 (pretty old, but would sure look good), International 1700, Ford F600. Don't have much money so I'm watching older trucks for sale. I would want something safe, not just the minimum. I know little about hauling in this weight range.
LoggerLee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 11:34pm
I've got a 76' Freightliner Cabover, runs good, needs some work, it's not pretty.
$2500
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 6:14am
Depending on what kind of trailer you are going to use, tag trailer or low boy 5th wheel.
 Brakes are the one side and power to go is the other .
I used a tandem dump truck to pull tri-axle lowboy. My old White 6 cylinder gas engine with 5 X 4 Trany would do fine on back roads but was hard to maintain minimum speed on parts of freeway, GMC with 427 with RT613 pulled the 37,000# excavator but again the same problem of top speed- both with the tag trailer.
 Air brakes are a must unless it's a new disc brake unit, trailer brakes are another . As whatever you use the DOT inspection will be required on both power unit and trailer, as well as Class A -CDL for the driver.
Edited by Coke-in-MN - 13 Jun 2012 at 6:16am
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 11:13am
my dad had a 69 chevy c65 with a 427 tandem axle one drive axle one air tag axle with air brakes  with a tandem axle lowboy  to pull his hd11 and he had to get a permit every time he moved it because of the blade with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 12:12pm
Weight range is set by axle bridging and load weight transfer . On a tag trailer figure you transfer 20% of load on pintle-hitch from trailer to the pull vehicle . in most areas the maximum load on a tandem axle is 34,000 IF the tires are rated for that . On a single axle truck 18,000 on the drive axle and rating of the front at mfg rate. A F8 would probably have a 8,000 front axle, then depending on tire size.
 A highway tractor is limited to 12,000 maximum on steer axle. A single unit like a dump truck can go up to 18,000 on the steer. I moved my CAT D6-9U on my tri-axle with 3  single tire axle running 9.50x16.5 tires figuring the weight transfer to the truck , but never got stopped or scaled it to see if it was legal . Then with the 9' blade I never permitted it either so was lucky.
Edited by Coke-in-MN - 13 Jun 2012 at 12:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 2:20pm
LOL I pulled a lot of things and im sure glad I didnt get stopped to see if I was legal.I pulled a d69u on a tag trailer using a single axle dump truck  with hydrolic brakes on the  truck and a hydrolic setup onthe trailer that the force from stopping worked the brakes .I pulled it one sunday morning i did a lot more preying that day then i did in church .
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 3:49pm
Unless you plan to move it a lot, it might be safer and cheaper in the long run to hire a local trucker witha lowbed, you are looking at up to 28-30,000#.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 4:43am
My 7G only goes at 23,000#, hired a hauler for the 120 mile one way trip and was just under $600.  I can't buy license or insurance that cheap and as we do not intend to ever move it again it worked out for us.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 4:38pm
Last 11B I looked at had a coplete with blade weight of 41,000#
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 6:00pm
My HD_11S weighs about 29000# with st blade, ripper and canopy..... a later model HD-11B would weigh a little more.... I just scrapped an HD-20 Push Cat that weighed close to 42000#.
