D12 Carb
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: D12 Carb
    Posted: 11 Jun 2012 at 9:12pm
Had to take the carb off of the D12 tonight. It seemed to be running lean, and wouldnt run unless the choke was almost closed. I tightened the manifold bolts and not any better. When I took the carb apart the high speed jet was fully plugged with rust. It has 2 numbers on the brass tag 235975 and 12740. Which is the carb #, and what model would it be.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 9:36pm
Looks like that number might be 12749
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 10:07pm
you only need to know if it's Zenith or Marvel.
Get a gasket, clean the jet and reassemble it. Bob
This page was generated in 0.112 seconds.
