xt problem
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: xt problem
    Posted: 11 Jun 2012 at 8:50pm
i have replaced my regulater  bout 5 times since 12/05 when i bought it. i dont kno why it goes bad so often the first 2 i got  from my dealer was bout 20$ and the next 3 was bout twice as much. it starts by over charging the batteries until i can smell the acid. then i took the top off and adjusted the bolt a little bit and it wont charge long enough to keep the batteries charged up. the alt was rebuilt and is good. is there anything else that will make this go bad???
                      Shawn
190XT,D17and 7045
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 9:14pm
Same problem a few years ago. New regulators made alternator run full charge all the time. Took cover off the new regulators and internals appeared to be "solid state". Auto parts store was able to find me an old style regulator with the internals just like the old one. Put it on and alternator has charged normally ever since. Good luck.
Steve
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 9:50pm
I put little matchbock size regulators that piggy back right on the back of an original altenator and makes them one wire hookups, got them at auto store. Not original but ends regulator problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 10:20pm
Replace alt. with later one with built in regulator. MACK
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 11:21pm
Cheap electronic regs are just that, cheap.
 For the last 20 years when a vibrating reg goes out, and point filing doesn't make it go any more, I replace it with an autolite (ford) electronic regulatore and make a wire harness adapter to match. They work great. 'cept like I said when you use a cheap cork gasketed one. and should isolate from vibrations and will last a whole lot longer...
 But even those regs are getting harder to get with all them one wire alts being around.
 Yea I know that some think delco and autolite shouldn't be mixed...LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 6:40am
cant change alt   it is my tach drive
190XT,D17and 7045
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 7:09am
i have the same trouble i need to replace my reg. now
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 8:10am
i would suggest you closely inspect wiring from alt. to reg. especially where it is routed behind oil filter and and areas like that. look for wiring that has insulation worn thru and causing a ground.  i have a horror story about this when i worked at a dealership years ago. hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 8:53am
Nice thing about the little regulator that piggy backs on your original alternator is you don't lose your tach drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 6:19pm
Anyone want to share the info on these piggyback regulators , ,,, who makes them ?? What applications/ models   do you ask for -- cause i can see the dumb look coming !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 10:08pm
Transpo part no d7014 for the piggy back  voltage regulator.   take out top bolt that hold your alternator together and put through regulator, unplug wires from tractor just need the big hot wire and plug in this little unit. I use it on a 190 running a 385 planter and has worked well.
Edited by DanWi - 12 Jun 2012 at 10:14pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2012 at 7:53pm
Try running a ground wire from the regulator to somthing other than the hood.
