7050 axle wedges
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 7050 axle wedges
    Posted: 06 Jun 2012 at 12:14pm
  I have a 7050 that I wanted to put duals on using the cast centers. I have a 7060 and 7030 parts tractor. Would the cast centers off the 7060 work on my 7050 axle. If I remember right the 7050 has smaller axles right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 1:12pm
Cast centers are the "same" but the wedges have to fit the axle.In other words,you can swap centers around as long as you have wedges for each axle size.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 1:14pm
Okay thanks, I figured the centers were the same but wanted to make sure
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 9:11pm
The axles should all be the same diameter. You will have to have the long axles on your 7050 to make your idea work. If you have short axles you will need the 'Mexican Hat' cast centers for your duals.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 9:19pm
The 7050 has 3 5/8" axles long or short and your 7060 would have 3 3/4" or some long axle 7060s had 4". The 7030 has the same diameter axles as the 7050.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 9:29pm
7010-7020-7030-7050-8010 all had 3 5/8" diameter axles...7040-7045-7060-8030-8050-8070 FWA all had 3 3/4" diameter axles in std length....7080 and 8070 2wd were 4 inch diameter. All rear wheel centers interchange but are not all the same P/N.
