WD 45 Brakes
Ron Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Nelson Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Brakes
    Posted: 05 Jun 2012 at 4:36pm
Does anyone have a way to get the bottom pins out of the brakes on a WD 45. Mine are frozen and I have heated them and haven't had any luck getting them loose. Any help would be appreciated. Thanks, Ron
Larrywdin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larrywdin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 5:47pm
I used the brake pin puller in the picture, and kept steady pressure on it, and hammered on the pin in the hole in the bottom of the casting, and eventually, it came loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larrywdin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 5:49pm
If you crank down on the pin too hard with this puller, it WILL pull the head right off the brake pin , so be very pationet,
Edited by Larrywdin - 05 Jun 2012 at 5:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larrywdin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 5:51pm
Here's the company that makes the pin puller
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 6:50pm
You can also cut head of pin off with tourch then cut about 1/2 " of the pin off working through mouse access hole in bottom of axle housing -- then drive pin in 1/2" and cut again untill pin is gone. the end that is in the diff housing will come out with vice-grips.  Do this job OUTSIDE as there will be much smoke from burning mouse nests, also wear FULL leathers so you don't get burnt!!
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 9:42pm
By the time that I got my hands on the family WD, it had been so long since Dad had done the brakes that he couldn't remember doing them.  But, after he passed on, I found his homemade puller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 9:49pm
Looks like one side was still stubborn, so here's another approach.
FHOliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FHOliver Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 12:01am
where you at in ill.
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 5:54am
    If you do end up going through the bottom to cut the pin off, be careful not to cut into the brake shoe hangers.  Dont ask me how I know that.
    One other thing, I know there is at least one company now that has new pins in stainless steel. Of course they are more expensive, but might be worth it.
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 1:02pm
I have to this job on my WD45 this summer. I have been lurking in the back ground on every post about this subject. It seems as though the pins are seized in the housings mostly at the outer ends. Once you get the outer area freed up the remaining problems are with corrosion buildup on the shaft making it difficult, but easier to get the shaft through the brake shoe holders. I have been giving the pins on mine a shot of every penetrant listed on this site and known to man every time I take the tractor out to mow. I was wondering how much it would help to warm the housing at the outer end of the pin,   chill the pin down by spraying a can freon onto the head of the pin while shielding the still warmed housing, spraying some penetrant on the area, and then start working the pin out?
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 1:07pm
I'd imagine your heat/cool theory works better on paper that in real life.I'd keep dousing it with 50/50 actone-atf especially from inside the hole.Have had very good results with that stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 1:21pm
Well at least we know that spraying one kind of penetrant on top of another doesn't cause an explosion be cause that's what I've been doing.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 1:41pm
Steve, the heat cool theory does work but may be hard to do with that small of a pin. It sure can't hurt to try it though. I have used that theory on much larger stuff with good success.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 8:59pm
a plasma cutter works real good on them pins...
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 9:43pm
JW this and your post in the bush hog topic made me laugh real hard.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Vinnie/S.D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vinnie/S.D. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 10:00pm
use a sawsall no smoke cut offs peaces  in the mouse hole and pound it in
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 2:03pm
good luck. arent those hardend steel? better have a diamond tipped blade
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 2:21pm
I tried a sawzall once, the pins laughed at me..........
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 2:34pm
Mine must have ben soft ,cause cheap sawsall blade went right through them
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 11:50pm
All my mechanical things get to laugh at me every so often.
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2012 at 3:26am
Heat the pin up in the mouse hole. Get a saw with skinny blades that can fit in there and cut a chunk out. Cuts much faster if u get in nice and red.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2012 at 6:40am
I did like this on my D17. I slipped a deep well socket over the welded on bolt and it drew the pin right out.
