WC HC Axle Code
ACEd2010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACEd2010 Quote  Post ReplyReply Direct Link To This Post Topic: WC HC Axle Code
    Posted: 05 Jun 2012 at 2:26pm
I have a WC HC with 36 inch rears and what appears to be an Axle code steel stamped into the raised flat on right of seat mount top line small letters WCDX followed by large 9 and second line 723. Also has steel tag (not legible) on one of the studs on front of left side of axle pumpkin / housing. I seem to recall there is a steel stamped code somewhere on 6.6:1 High Traction Axles to distinguish from the  standard 4-4/7:1 axles. Is this the code and can anyone decode it? Or is there a code stamped somewhere else. Thanks Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACEd2010 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 12:02pm
Maybe WCLX - see picture of raised block on right side of differential outboard of seat mounting.
