B/C Gas Tank Restore??
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: B/C Gas Tank Restore??
    Posted: 02 Jun 2012 at 11:06pm
What is the best way to get all the rust and grime out of a old tank and to make sure it will be reliable?
Can't fix stupid
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 8:41am
Hi AJ. See if you can find a radiator shop and have them hot tank it. If it's pin holed on the bottom, they can usually fix it for you also. I was lucky to have worked at a place that had a plastic medium blaster that could reach inside a tank. It cleaned off the gunk and loose rust leaving a great surface to tank coat. Mike
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 8:53am
Thanks mike.
Can't fix stupid
