1222 Corn Head on R72??
Mark D. View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Topic: 1222 Corn Head on R72??
    Posted: 01 Jun 2012 at 10:06pm
Finally got our corn head home for the narrow rows.  It is a newer gleaner head and it doesnt sit right on our R72.  The bottom of the throat doesnt line up with the bottom of the header throat.  Is there some kind of adapter that we need?  The dealer we bought it from didnt mention anything else we would need.  Thanks!!
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller
Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 11:41pm
If your R72 does not have lateral tilt the. You can either modify the head to fit your combine or adapt the combine to fit the head. If you also have a grain head then I would recommend adapting the head. If you post the serial numbers of your machine and head I can get the part numbers for the adapter kits.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 4:55am
No, we do not have lateral tilt on the combine.  I will work on getting those numbers on here sometime today.  Thanks for the help!!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 4:00pm
Here they are:
R7214013
1222RHMZ7630
Thanks for your help!!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 8:52pm
Still waiting for your help "soybreedingboy77".  Thanks!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 4:38am
Bump
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 5:18am
Mark D. Click on his name and send him a PM direct. Could be he's busy and hasn't been back on the site or forgot about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 8:48am
also check over at thecombineforum.com
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 10:30am
Mark
You will need 2- 71379541 which are the blocks for the sides of the throat to close the gap, also have to un bolt the top plate and move it down to the bottom set of holes.  If you have any questions you can call me at 800-996-2937.
Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:00pm
My cousin from the dealership got back with me on the part numbers for your conversion.
To adapt the for head to fit on your combine you will need to
"Move header top truss to non-Smarttrac position using parts below.
(2) - 71379541 - Non-Smarttrac Guides
(1) - 71383723 - Shield/Filler
(1) - 71383719 - Stiffener
He said the price for the parts if they ordered them would be
around $450.00 plus freight to your location or picked in Watseka, IL
