One sharp stone away from losing my 180
 Rating: Topic Rating: 1 Votes, Average 3.00  Topic Search Topic Search  Topic Options Topic Options
fwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fwo Quote  Post ReplyReply Direct Link To This Post Topic: One sharp stone away from losing my 180
    Posted: 01 Jun 2012 at 11:28am
..and my calcium.
This is my fault for waiting so long but I need a decent used 18.4 x 28.
Apparently they aren't made anymore.  I found one overpriced new one 4 states away but really want a used one because my other one is still OK (not too good but OK).
I'm in Ohio.  Thanks.
For years I ran it with the fabric showing but now there is a bubble of tube showing.
Kindest regards,
F. W. Owen, Homerville, Ohio
http://www.HomerProduceAuction.com
Owenlea Holsteins
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 11:53am
Looks like you need a "rubber welder" .. I would suggest a boot for temporary but that would be a lot of work for short time it would be used. That is hope it is short time till you find one.
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 6:00pm
I realize that you want to fix it the right way, but if finding a tire is a pain, I have used some flat baler belting and glued it in as a boot before. Lasts a long time. The calcium is going to make it a little difficult.
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 8:08pm
You might try Miller Tire.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 8:15pm
my dad just bought 18.4X30 tires and rims mounted for 1800$ at millersburg tire  in ohio they are brand new firestones 23
190XT,D17and 7045
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 8:41pm
I may have a set of 18.4x28s available in the future. If you are interested, give me a shout, right now they are mounted on steel 8 bolt wheels(still on combine) that would bolt onto a WD. Still working on getting the whole machine. Tires appear to be very good and almost 100% tread, matched set. East-central MO.
Leon B MO
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 8:54pm
tiretown.com has both new and used tires.  I Would put two new on and not worry about it again.  I put new tires on all my tractors and haven't touched them since. Even the  C that I bought in 1986 put new tires on it then still great. they are not going to get any cheaper.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 9:08pm
Firestone makes new 18.4 x 28s.  I put a set on my 175 last year - not cheap though!
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 12:47am
i have a pair of good year takeoffs that i replaced earlier this year
they are ugly but not as ugly as yours,
 i will give them to you if you want to come get them call me @270-670-3480
they are 1 hour south of Louisville, ky just off I-65
i like old tractors of all colors
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 1:34am
Leon...Might those tires that you have on the combine be 26" ? I know I have a matched set of 18.4 X 26 Firestone's on my D17 Series III and love them!  Rick
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 5:04am
YOU CAN SEND IT OFF AND HAVE IT "VULKINISED".
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 5:15am
CT is right...I had a rear tractor tire vulcanised  several years ago locally and the guy guaranteed it for two years,which I thought was plenty fair. Back then it cost me 200.00,but it was a 16.9 X 34 tire with about 40% tread.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 6:51am
WELL worth the trip to Kentucky! Depends what you do with the tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 7:45pm
the free tires were holding air and i plowed with them this spring, they are road worn but i would not be afraid to put them on a tractor if i needed a pair or a spare, but i realize you are looking at a day trip to pick them up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 10:36pm
update, i just got a call from a local guy wathing this site and he is going to pick up the tires tomorrow if nothing happens to prevent the pick up
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 6:00pm
the tires in ky are gone
