12V Generator
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: 12V Generator
    Posted: 31 May 2012 at 8:45pm
Has anyone put a 12v generator on their tractor not an alternator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2012 at 9:04pm
Absolutely. A lot of folks like to keep the OEM appearance with a Generator, but also like to upgrade the older 6V system to 12V. In most cases, a voltage regulator is used in conjunction with the Gennie to help with the regulation of charging chores. I change over 6V gennies to 12V. You also can install a 12V gennie from a 50's GM product. Depending on what model Tractor you have, if your Tractor is a B,C,or CA model for instance, you can "hide" the VR in the toolbox, or if you're not that critical on the look, piggy back the VR on top of the Gennie. We offer wiring systems for those who want to move to 12V and a Gennie.  If you want to keep the Ammeter, it would be a good move to upgrade the Ammeter to a 60/60 sweep and loose the OEM 20/20.  OR you can go to an optional Voltmeter in lieu of the Ammeter. Make sure you upgrade the switches if you decide to move to 12V. When getting a Generator, always mate a VR to the Gennie by using the ID tag number to ID the max output of the Gennie if there still is a tag on the unit. HTH....
Steve@B&B
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2012 at 9:10pm
I have done what Steve said on the last 4 or 5 CA's/Bs I have rehabbed. They work great and with the VR in the tool box, they look original and work great (the tractors don't need much amps charging since they do not have a lot of electrical equipment on them).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2012 at 11:12pm
I put a 12V generator on my WD45.  Put the VR on the front of the battery box.  Works great.  Used the factory 6 volt mounting bracket and just used a special thick bushing on the rear mount to bolt it up since the 12V genny is longer than the 6v.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
