"B" front end? Any hints or tricks? "UPDATE" |
Post Reply ![]() |
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
![]() ![]() ![]() ![]() ![]() Posted: 30 May 2012 at 9:49am |
Is there any hints or tricks to get the "straight" front axle to move? It has been soaking for too days, I have given it a few good wacks with a large sledge hammer but it wont budge.
![]() Edited by R.W - 09 Jun 2012 at 2:27pm |
FloydKS ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: S E Kansas Points: 8431 |
I was trying to remember what we would do with ours (D-14 and 17) back in the day... but maybe they had not been setting so long and 'stuck together' as much
sorry I do not hav any good hints, or better than you are doing.
GBACBFan ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Electrolysis
are genuine." - Mark Twain |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10827 |
Take the bolts out. Put smaller ones in, don't tighten them tight. Drive it over plowed ground. It might help to loosen it up. If the axle has a bolt hole showing out of the tube, I made a fixture to bolt to it and use a hyd jack. HTH Tracy Martin |
WC7610 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Sioux City, IA Points: 764 |
Seems like on the D 17, you put a bolt on the spindle somehow and turned the steering wheel and the force from the tie rod slid it in/out (would sure have to be loose)? maybe I'm dreaming.
Thanks
Most Bad Government has grown out of Too Much Government- Thomas Jefferson |
Yes, if everything is loose that tecnique would work, you are not dreaming. I do remember using that way of changing the front... but power steering or steering by 'armstrong' is not enough if there is any thing sticking.
Well I put it back together and I'm going to keep soaking it. I got another tractor I can put the cultivator on, and that way I can keep the B narrow for the veggies!
Thanks Guys!
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
RW I used a porta-power on one of mine that had set for years. I left bolts in one side and got it to move then did the other side. I put pressure with the porta-power and one hit with a big hammer and it was moving.
If it comes down too it, I have a neighbor with a prota-power that might help me.
Glockhead SWMI ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
yep, I used a jack and put pressure on it then smacked it with the BFH!
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
The B front axle is different then the D series. The opening is at the top on a B, not on the underside. This allows water to get in and lay there. I have a B the I have been running without any bolts in it for 5 years and nothing has moved. I haven't soaked it lately, but did a lot of soaking years ago. Bob
Well its apart...and nothings broken.
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Looks like your center pin hole is worn like mine was . I got two bushing to go from cat 1 to cat 2 three point hitch and a 7./8 hitch pin and repaired mine . one bushing was not long enough . put bushing on pin and welded stright . squared it all up and filled in axel around bushing. . User hitch pin for it to swivel on ,had big head and could get a good weld./
Center hole doesn't look to be worn "its perfectly round" there is a bushing that is worn and I will replace along with a new pin.
Is there supposed to be a bushing in the axle or has mine been bored out and the bushing been made?
Post Reply ![]() |
