WC Maintainer
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: WC Maintainer
    Posted: 30 May 2012 at 7:07am
How many wc maintainers did allis make? Are they common? What are they worth? I think these things are so cool. Like to get one someday to restore.
Can't fix stupid
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 8:33am
the single front wheel? Im thinking there were only like 100 or 200 built.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 8:36am
There were 411 of the AC Maintainers made. I have a 1938 unstyled one. I do not think there are very many of them accounted for.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 10:05am
So these would be classified as semi rare.
Can't fix stupid
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 10:43am
Calvin S.  can put some light on this one .He tells me that with mine and Dale's he only know's of less then 10 he has on record. Start SAVING !!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 10:49am
Let's see pictures of the one's we know of .Dale if you e-mail me a picture I will post your's . Here is My 1939.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 11:25am
It's a shame there aren't more of these left. These things are some unique.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 11:27am
Did they make any other models of the maintainers besides the WC?
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2012 at 11:28am
By the wag Fred, your maintainer looks awesome.
Can't fix stupid
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 12:55pm
As was stated there were 411 Speed Maintainers built in 1938-1940. There was the early version like mine, a few with the square grader frame on the styled tractor, and the final version like Fred has. I know of fewer than 10 of all versions. This is my 1938 at the GOTO in Union Grove in 05
Edited by Calvin Schmidt - 01 Jun 2012 at 8:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 1:09pm
Anybody have a picture of the square frame on the styled tractor?
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 1:12pm
Jack Gustafson had one on a newer WC but the only real evidence that I have is a magazine ad from 1939.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2012 at 3:00pm
think you could post that advertisement for me to save? I have a collection of advertisements and brochures on my computer I've saved over the years. If I ever do anything with it I will be sure to give you credit. Handshake
German Shepherd dad
#WD234847
#WD88193
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 7:00am
What is the diference between maintainer and speed patrol? thanks
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 7:19am
speed patrol had the elongated wide front end. and came after the maintainer
Edited by acwdwcman - 02 Jun 2012 at 7:20am
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 8:18am
Maintainer has pressed steel rear rims'.W-Patrol Has the heavey cast center with clamp on rims .
Rear gear's are slower in the W-Patrol
And as already said ,front end's .
The Maintainer also dose not have 2 clutch pedals ,Maintainer's only have 1 pedal as a regular WC ,no clutch pedal under axle houing out to rear plat fourm .Patrol has back clutch pedal ,
that could be used for standing up while Gradeing .
There are a few difference's
Maintainer dose not have a wide plat forum to stand on .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 8:21am
Maintainer dose not have a wide plat forum to stand on while operating ,and to also beable to use rear cluct pedal..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 8:22am
Maintainer dose not have a wide plat forum to stand on while operating ,and to also beable to use rear clucth pedal..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 6:00pm
The operators manual that I have calls it a "Speed Maintainer attachment for WC tractor'
Likely most left the factory as a unit, but it would appear that the attachment could have been ordered for an existing tractor. Speed Maintainers have a grader and a tractor serial number. Speed Patrols do not have a serial number on the tractor pumpkin. My Maintainer was cobbled onto a Farmall H when I found it so I traded a WF for this WC with a serial number in the correct range. Other than the single front wheel the tractor is a standard WC. Unstyled versions did not have fenders because the fenders interfered with the blade lift.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 6:10pm
Nice Calvin! I like the looks of that unstyled!
Galatians 5:22-24
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 11:00pm
Was there such a thing made like this in a C version? Or after market accessory?
Can't fix stupid
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 12:06am
Drott made a grader attatchment. I've seen them on a WD and I think a B if I remember right.
I think it was Drott.
Edited by MNLonnie - 03 Jun 2012 at 12:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 6:37pm
I have seen a couple of them on a B. There was one on a B at George Suttons auction at Litchfield, Il. a few years ago, do not remember what it brought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 8:37pm
I believe that is a Drott grader attatchment??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 9:03pm
Drott made a lot of industrial equipment for AC and other tractor companies, I have an IB with a Drott sickle bar mower on it. It has 2-2 way hyd. cylinders and is ran by hyd. with a front mount hyd. pump.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2012 at 11:06pm
I would like to find one of those attachments.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 6:33am
Speaking of Drott I find it interesting that years ago Ed Drott who started Drott Caterpiller Co was a hobo who was pennyless along with my Grandfather. They had nothing and rode the trains looking for work any kind digging ditches, splitting firewood for a meal ect. They even threw a rock through a sheriff office window in Montana so they would get arrested and get something to eat. They went in a field and ate frozen turnips for Christmas dinner once. Good people but hard times. My Grandfather died owning a very nice farm which is still in the family and Ed died with a owning a huge company. He died speaking at a board of directors meeting. They kept in touch with each other many years .
